  New Posts New Posts RSS Feed - Boat-away kit
Boat-away kit
Post Options Post Options   Thanks (0) Thanks(0)   Quote ultrarunner Quote  Post ReplyReply Direct Link To This Post Topic: Boat-away kit
    Posted: June-12-2020 at 12:08pm
So, now that I'm in the trailering-crowd, I'm putting together a 'boat-away' kit, AKA "fly-away kits" that we have on our planes, for when we break down in places we shouldn't even be at...
So, at this point I have:
1. Both drive belts (GT40 EFI)
2. ECM fuel pump relay
3. 2 impellers and gasket goop.
4. Associated tools to change above, and tighten clamps, etc..
Anything else? Fuses?
Thanks,
Ultra
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donald80SN Quote  Post ReplyReply Direct Link To This Post Posted: June-12-2020 at 1:15pm
For Trailer:
Hub assembly, and jack for trailer. If pickup carry a floor jack.
Spare tire.
Boat:
Back up prop. Tools to remove prop.
Replacement bulbs for anchor and marker lights.
1968 Ski Nautique, Project.
zwoobah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote zwoobah Quote  Post ReplyReply Direct Link To This Post Posted: June-12-2020 at 3:07pm
Weekend Saver prop change kit from Acme
Battery jumper pack
Spare ignition key
Spare deadman lanyard/clip, if your boat is so equipped
Quart of oil, quart of trans fluid
Post Options Post Options   Thanks (0) Thanks(0)   Quote ultrarunner Quote  Post ReplyReply Direct Link To This Post Posted: June-12-2020 at 3:16pm
Good gouge guys. Yep, got a puller and bulbs. Hadn't actually thought of grabbing an extra prop, but makes sense for vaca trips....
Orlando76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: June-12-2020 at 3:39pm
Unfortunately the list is endless. I’ve replaced trailer springs on the highway. Been times where I’ve had complete hub and tire but damn it I needed two hubs and tires. A voltage checker is something I can’t stand to leave home without but I guess that’s the electrician in me. My suggest is put together the best kit you feel necessary and add paper towels and hand cleaner to it and always carry a case of water with you. I only break down at 1pm when it’s 110* in July and I’m in a hurry and make a mess with bearing grease.
1976 Ski Nautique 351 Escort
burban65 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote burban65 Quote  Post ReplyReply Direct Link To This Post Posted: June-12-2020 at 5:51pm
+1 on battery jumper pack and spare boat key
Trailer tail light bulbs
SRB
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-12-2020 at 7:19pm
Were are you planning on carrying all this stuff? In the boat or leave it in the tow car/truck?
GHTILL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GHTILL Quote  Post ReplyReply Direct Link To This Post Posted: June-13-2020 at 12:51am
Lets don't forget to carry a jump starter battery. Might come in handy on the lake. Small and inexpensive.
TWSS
Post Options Post Options   Thanks (0) Thanks(0)   Quote ultrarunner Quote  Post ReplyReply Direct Link To This Post Posted: June-13-2020 at 10:58am
Yeah, the heavy road-trip stuff is in the vehicle, like extra pop, jump starter, stuff like that. I'll keep just the basics in the boat...bulbs, impeller, belts, pump relay, etc..
With that said, anyone here have a bulb light-socket with the male wire stalk that goes into the back of a gauge? I noticed the one on the fuel gauge is missing as I had the dash pod off tracing down a loose connection to the nav light.
Thanks,
Ultra
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2020 at 11:14pm
I’ve always been “trailer trash,” impeller, belts, relay in the boat everything else you can limp it back to the truck for.
Our local trips (<1hr) Basic tool kit spare and jack.
Week long+ vacation then the list gets involved.
Fabcon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fabcon Quote  Post ReplyReply Direct Link To This Post Posted: June-15-2020 at 3:21pm
I always pack heavy with spare parts on boat trips and leave them in the truck box. I figure you came always get a tow back to the boat ramp and if I need it it`s there.
1984 Barefoot Nautique (Parting Out)
