  New Posts New Posts RSS Feed - Whining Fuel Pump
Whining Fuel Pump
jedgell2000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jedgell2000 Quote  Post ReplyReply Direct Link To This Post Topic: Whining Fuel Pump
    Posted: June-19-2007 at 12:27am
My '95 GT-40 has started making a whining noise while running, only notice it at idle. It sounds like a Chevy fuel pump. Its been doing it for a few weeks with no problems. Last weekend the boat had to turn over 10-15 times before starting, never had that issue before. Are these signs of a failing fuel pump? If so, which one, the low pressure, or high pressure? I do not have the FCC. Thanks,
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: June-19-2007 at 12:33am
sure sounds like the electric fuel pump is going, are you seeing any performance issues? You should see them on the top end first due to a possible low pressure caused by the pump.
