Anyone tinker on Evinrude/Johnsons? |
Author | ||
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Online Points: 21130 |
Posted: March-20-2012 at 1:47pm |
Probably a long shot, but figured it wouldnt hurt to ask! I have four 9.9/15hp Johnnyrudes from the '74-86 era that need some work. One runs, but starts poorly when hot. 2 others are complete, one is a parts motor. I'd like to put together 2 good running motors out of the bunch. The problem is finding the time to work on them!
If anyone in the northeast works on these things in their spare time, drop me a line and I can give you some more details. Im located in CT. Thanks! TRBenj@gmail.com |
Hollywood
You are going to end up on American Pickers some day...
Riley
Grand Poobah Joined: January-19-2004 Location: Portland, ME Status: Offline Points: 7952 |
Tim, I've got an '87 9.9 Johnson I bought new. I have an excellent service manual that tells you how to repair everything and also tells you specifically what not to do! You're welcome to borrow it.
Jllogan
Platinum Member Joined: May-18-2011 Location: canton, OH Status: Offline Points: 1728 |
I'd love to see that episode! Maybe we should submit his name and address to them. American Pickers contact |
Ha, thanks HW- if only I were retired, Id have more time to turn this "junk" Ive collected into useful stuff!
Bruce, Ive got a full service manual for my '86 and can handle the basics... just dont have much time to dedicate to these at the moment. Too many irons in the fire! Want to trade that '87 for a few clunkers? |
Bri892001
These old two strokes would probably worth a few bucks in running condition. Seems like the industry is mostly moved to four stroke for motors in this range, which I'm assuming are a good deal heavier.
Looks like the E-Tec is one viable option though. |
I had to look up the latest offerings and youre right- hard to believe that 2-strokes arent being sold anymore! Ill stick with them as they have a significant weight and performance advantage.
Evinrude still has some work to do to bring their E-tec technology to the smaller motors. They just introduced the 15HO, but it weighs a good bit more than their standard 15hp (183 vs. 114 lbs). My understanding is that its basically just a detuned 25hp or 30hp motor, as the e-tec components havent shrunk yet. |
quinner
Maybe you and HW can team up on this one. Double Dutch Rudder?? |
Tim,
Before you do any work on ether, check the compression, I have two 15's from the same era. I put lot's of hard time on them, the ski club put one of them on their Fliver and lots of hard time but then my son killed both of them!! |
Im definitely going to test them, Pete... from what Ive read, this era of motor is pretty robust and not many suffer from low compression. I suspect that may be the case on the '86 9.9 that I have though... I ran the snot out of it when I was younger, and now it doesnt start well once its warm.
CQ, are you saying HW should be able to work on my Johnson because he's pretty handy? |
Hollywood
I'll work it with my boot.
Bri892001
Interesting on the difference between the two 15s. I just assumed they were all E-Tecs, but I noticed the Portable Series is not.
I was eying the Evinrude 9.8 because we have a Merc 8 that's a little tired and has a fuel delivery problem. We can't get the bulb to get firm... |
skutsch
Grand Poobah Joined: June-19-2008 Location: Racine, WI Status: Offline Points: 2874 |
Tim, pretty simple to work on (and fun too), I used to take them apart or maybe try to put junk motors back together so I would have something to run on the old Mississippi. As Pete said, if the compression is good, then it's either a bad carb or a bad coil, as my uncle always said, its either got no spark or no fuel.
Time to play with it is a completely different scenario/problem... |
Yup, simple to work on for sure- I tuned up the 9.9 a few years ago and got it running ok after sitting for 10 years. These need more part swapping than just a tuneup though. I know I could handle it, but Im no expert on them- so Im sure there are people out there who can do it faster! With 2 houses requiring some major projects this spring and 2 CC's in pieces that need to get reassembled, I just have WAY too much on my plate to get to these anytime soon. And having a reliable little runabout at the dock is pretty much a necessity... so I need some help!
tullfooter
Grand Poobah Joined: March-02-2007 Location: White Lake, MI Status: Offline Points: 2225 |
My wife works on my Johnson. But I don't let her touch the two on my boats.
Play hard, life's not a trial run.
'85 BFN '90 BFN White Lake, Michigan |
Hollywood
Interesting theory Steve. I have a standing practice to not let my Johnson touch another Johnson on a boat, or any other place.
jbear
wives and johnsons in the same sentence..must be young guys.
john |
"Loud pipes save lives"
Waterdog
I,ve got 1962 Johnson Twin 3hp and one for parts. Best thing I did was install a ignition. The the coils were hard and brittle. All the ignition parts were about $110.
WE put in on a old 17 ft canoe with a 2x6 and C claps. Only me and my brother have piloted it. Amazing how unstable a canoe is at 20mph!"It will make your butt grab the seat" |
MAN - GA
Senior Member Joined: July-09-2009 Location: Cumming, GA Status: Offline Points: 298 |
I just recently went through this with a 40hp Spirit (Suzuki before they actually imported them under the Suzuki name)on my Lund. I went through everything trying one thing at a time and what I finally found was small crack in the fuel line between fuel pump and carb. Fuel delivery on these is pretty frustrating to figure out sometimes b/c I kept wanting to go to the carb so I guess the moral is to check all the simple things first and don't make any assumptions |
Bri892001
I was making a slight play on words but I was serious. Literally the squeeze ball on this used to firm up as you primed it and now it does not. It looks like there is a little crack where the fuel line goes into the tank, and I thought that was the culprit. I haven't really gotten into it yet. But, that doesn't totally make sense since the tank isn't made to hold pressure anyway (we used to have an old Johnson that used a pressurized tank to feed the fuel). I'll check the fuel lines under the motor cover then too. |
GottaSki
Grand Poobah Joined: April-21-2005 Location: NE CT Status: Online Points: 3334 |
Fixed it there for you , jbear |
River Rat to Mole |
Dreaming
I'd guess that there is a check valve in the bulb that won't let the pressurized fuel back to the tank. if your supply line on the motor side of the bulb has a leak, that would definitely keep the bulb from firming up. also, if the check valve was weak or non functional, it would have the same effect. |
dochockey
Gold Member Joined: September-16-2009 Location: Colorado Status: Offline Points: 638 |
I just put My dads 85 Evinrude (1976) on our pontoon (Harris float tug)
still works great ! It must have been made on a Wednesday |
1989 Teal Ski Nautique
1967 Mustang Harris Float Sunfish |
