Transmission Oil Heat Exchanger. |
CamSweet
Newbie Joined: January-10-2005 Location: United States Status: Offline Points: 14 |
Posted: August-03-2017 at 8:24pm |
Fired it up for the first time this year and have a split at the seams...Doea anybody know the part number for a replacement? 1980, 351 PCM.
THanks, Cam |
1980 SkiNautique
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10648 |
Here's a link to the the right cooler
You may find it elsewhere for less if you look around. 5 inch body 1 inch water hose fittings 3/8 NPT oil line fittings |
CamSweet
Thanks Keno!!
1980 SkiNautique
Glad to help
Cameron,
You need to drain those things before the freezing weather sets in. |
CamSweet
I see the drain plug, now... Never had before, however it was inside most of that time. The poor ol' gal hasn't been out in 12 years... I found NautiqueParts.com has it for $10 cheaper...
Thanks, guys... |
1980 SkiNautique
Cameron, I suggest not using the drain plug even IF the new one comes with one. The cooler is thin copper and if the plug is tight, removing it can twist the shell of the cooler and in some cases the plugs threaded boss can break off. BTW, many have been repaired. Get the solder, flux and iron out if you what to save some $$$. |
