1963 Correct Craft Atom Skier |
Post Reply | Page <1 456 |
Author | ||
NewOwner
Groupie Joined: November-16-2017 Location: MO Status: Offline Points: 58 |
I have moved the boat to Ten Mile Lake in MN and have started removing the screws from the bottom. Is each side of the hull one piece?
NewOwner
I have all of the screws out of the bottom. Should I also remove the screws from the piece of wood down the middle and on both sides? When I replace the bottom, what kind of ply wood do I use? Is there a pattern or do I use the old bottom?
juniorwoody
Gold Member Joined: August-09-2011 Location: Oak Hill, Fl Status: Offline Points: 937 |
I used 3/8 marine plywood. I believe that's what is there. Each length is made of two pieces joined end to end with a scarph joint. Need to use epoxie.
The value of money spent on new adventure far exceeds the value of money saved for the future
Don, Yes, the screws at the keel need to come out.
As Jack mentioned, any painted surface, use 3/8" marine Douglas Fir. Marine grade ply has very controlled specs on inner ply voids. Any bright (varnished) needs the Mahogany. Also as Jack mentioned, anything over the typical 8' ply length needs to be scarfed and epoxy glued together. Scarf joint with a ratio of 10 to 1 to 12 to 1 thickness to scarf length. Patterns are not available. Use your old ply for a rough pattern and then do any final trimming on the hull. Do you have the frame braced, squared and sitting on something level? With the ply off, the frame can twist. |
