hours on engine |
emccallum
Platinum Member Joined: August-08-2006 Location: Clarks Hill SC Status: Offline Points: 1084 |
Posted: August-23-2006 at 10:16am |
Curious... how many hours should we expect to get out of 351 PCm motors before rebuilding? a$$uming it has been pretty well maintained. I have a friend that is looking at a 98 SN with about 800 hours. Both my boats have around 400-500 hours, so I have never really dealt with higher hour boats. All thoughts and comments welcome!!
ernest |
great78
Senior Member Joined: October-04-2005 Location: United States Status: Offline Points: 103 |
I resnetly sold my 78 with about 800 hours on it and have a 72 with about that many, running strong and no sign of slowing down. It's all maintainance related. If you consider that 5,000 hours in a vehicle equates to about 100,000 miles, the difference between 600 and 700 hours is minimal. Mostly boats suffer from lack of maintenance. A 98 with 800 hours can be had for a significant discount but you should varify engine condition, compression, oil sample, etc. I guess the bottom line is you really cant tell much strickly from an hours standpoint.
AWhite70
Senior Member Joined: March-05-2004 Location: United States Status: Offline Points: 242 |
A friend of mine has a well maintained '82 SN 2001 that he has owned since almost new. It has 1700+ hrs on the original engine and still runs like a champ.
quinner
I have heard 50hrs is an average season and a motor should last 3,000hrs before needing a rebuild, curious if 3k is an accurate estimate.
2_Nautiques
Senior Member Joined: March-22-2006 Location: United States Status: Offline Points: 251 |
I read in a recent Water Ski magazine that marine engine hours can be somewhat compared to auto milage by adding 2 zeros to the hour meter. My 88 has 1315 hrs which would mean that it's mileage would be 131,500. By the way the 88 runs great and maintains good oil pressure with over 1300 hrs.
The Dude
Platinum Member Joined: October-19-2004 Location: Houston Status: Offline Points: 1334 |
Mullet Free since 93
95 Sport |
GrandSlam
Groupie Joined: May-15-2006 Location: United States Status: Offline Points: 63 |
Earnest, the number of hours is a tuff to estimate. My boat usage for example has many hours trolling at either an idle or just slightly above while most of you ski guys are typically running their boats at 3 grand or more most of the time, then there is fresh water or salt water that can pay a role as well. Don’t forget the toll of time – age in years, often boats that are run more frequently will last longer in hours than boats that sit. A close friend purchased a damaged 25’ Slamrock that had been used as a TowBoatUS. He fixed the damage and at over 2,800 hours the PCM 351 engine is still strong. It is encouraging to hear about the many hours that some people get out of the “tried and true” 351. Have a great weekend, Jerry
Jerry Troy
USCG Master, 100GT 1989 23' Fish Nautique 1992 47' Jersey SF |
87BFN owner
I see your worry, I was the same way when I went to buy my BFN it at 1275 on it when I baught it. As long as it was maintained 800 hrs is not that many.
behindpropeller
Hours on the engine do not mean much, its just a number.
I am more concerned about corrosion than hours. If the boat was ran 50+ hours per summer and properly winterized every year you will have less problems than a boat with 200 hours on it and being 20 years old...... Tim |
Chopper
Gold Member Joined: June-15-2006 Location: Australia Status: Offline Points: 821 |
We have a 98 ski with just over 700 hours now. Not a hint of any problems.
