acme prop |
87BFN owner
Posted: October-27-2006 at 4:21pm |
On my 87 BFN is a 14x14 Rh prop with a 1 inch shaft. Shaft size I am pretty sure about but would have to go look to be positive. Anyway I keep coming across all these posts about acme props, I have been to a couple different site but have not found an acme prop in a 14x14 size.
Any help that can be offered I would be greatful. Thanks in advance. |
Hollywood
I would go with a 470. 12.5 x 15, the 654 has the same dimensions + 1 blade and $15.
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=4917&KW=barefoot+acme Still don't know what a 480 is though. |
87BFN owner
thanks hollywood
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21129 |
I would call Acme and get their recommendation. The 470 is really meant for the 1.23:1 boats, but your 454 may be able to turn it. What are you getting for max RPM now?
79nautique
the 470 is also recommended for the big block motors besides the 1.23:1 trannies even thou I use it on my 1:1 set-up.
