  New Posts New Posts RSS Feed - 2001 Transmission Fluid Change
tjamesbo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tjamesbo Quote  Post ReplyReply Direct Link To This Post Topic: 2001 Transmission Fluid Change
    Posted: July-14-2008 at 11:01am
Going to Change my Tranny Fluid and am looking at draining it out by pulling the bottom hose that runs up to the cooler only question is do i pull the right angle connector out or just the hose ( see piccie ) seemsto me the whole connector should come out in order to get the maimum drain? also the manual mentions some kind of Strainer in there it looks small anything to watch out for ???
I must admit I'm also tempted to disconect hose at the cooler and pump it out what are the pros and cons of either ???
How do I upload a piccie ???
Greetings from the cold and wet UK where the weather can only get better!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote tjamesbo Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2008 at 12:34pm
here is the picture of hose bottom   undo the hose and rotate the angle connector or remove it ???
88 Nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 88 Nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2008 at 12:37pm
A lot of us here just pump it out of the filler. I didn't heve a pump the first time I did it but I had a large syringe, (30cc). Hooked some tubing to it and sucked it out. Took a while but I was able to empty it pretty good.
For posting pictures, here's a good link:
Posting Photo's
Kurt
Post Options Post Options   Thanks (0) Thanks(0)   Quote behindpropeller Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2008 at 2:25pm
Looks like some cleaning is in order before you start your fluid changing project.
74SkiNautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 74SkiNautique Quote  Post ReplyReply Direct Link To This Post Posted: August-05-2008 at 9:37pm
hey...I use a pump. I got mine out of an overtons catalog. I have a B/W 1:1. Just stick it in the filler and you should be able to get most of it out!
   http://www.overtons.com/modperl/product/details.cgi?i=71783&pdesc=Hand_Bilge_Pump&str=hand%20pump&merchID=1008&r=view
Something like this should do it.
74SkiNautique
Sam B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam B Quote  Post ReplyReply Direct Link To This Post Posted: August-06-2008 at 11:07am
I bought a simer drillmaster pump some fittings and hose then good to go.
Maximum pumping capacity up to 225 gallons per hour
It's multi-purpose ability allows it to pump water or change oil in lawn mowers, boats and cars.
Minimum drill speed 1200 RPM
Model CM10 - 1200 RPM
Check out Simerpumps.com
Hope this helps Sam
Loud pipes save lives!!
2011 Green Lake Reunion Best of Show.
Sam's 73
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: August-06-2008 at 12:24pm
Careful not to let the hose fall off the end of the hand pump into the case.
hunterdan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunterdan Quote  Post ReplyReply Direct Link To This Post Posted: August-06-2008 at 1:03pm
how much oil do you put in. For the 1:23 what oil do you use??
Dan
