  New Posts New Posts RSS Feed - changing oil with drill pump
kapla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Topic: changing oil with drill pump
    Posted: March-09-2009 at 2:42pm
Every time I change oil I do a mess, I feel like a redneck. I start with the manual pump through the dipstick, but after 100 strokes under the sun only 1 quart is out!!! I do have the drain hose but the drain plug in the hull is frozen so I canīt use it.
I wanted to get the vaccum pump as the one on skidim (but is not available here in argetina). So my question is have anyone used the pump that attaches to a drill? Is it good or is it junk?
I ussually end placing a bag under the oil pan and unhooking the oil drain... Imagine the mess...In the bilge and carpet when trying to get it out... At least my carpet is dark so any oil spill gets easily match with it...
I know you gonna hit me hard for this!!!!
So start shooting on me!!!!
<a href="">1992 ski nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: March-09-2009 at 2:49pm
Sebastian, youve gotta get that drain plug unstuck! I cant imagine not having one- what if your boat fills up with water while youre on the trailer? My plug is out any time the boat isnt in the water.
I dont have the oil drain kit on my older boats- I use the Suck Up from SkiDIM to pull the oil out of the dipstick hole and it works well. It goes much faster if the engine has been run up to temp!
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: March-09-2009 at 2:54pm
I was planning on making a new plug with a throug hull but still wondering if a good idea... regarding the old plug is hard to get any tool there to try to unbolt it...any tip will be appreciated...
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: March-09-2009 at 2:59pm
it's a pipe thread and seals pretty good there should be a square section above the threads and where the t-handle's base starts, grab an adjustable wrench and you should be able to unscrew it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: March-09-2009 at 2:59pm
Its just a T-handle, correct? If you cant get it off by hand, get some leverage on it. Pipe wrench, vice grips- anything. It should come loose if you hit it. Spray some penetrating oil on it first and let it soak for a few days.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: March-09-2009 at 3:05pm
Yes is that square head plug there, no t handle... Its a tight spot to work on...
I have to solve this asap.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: March-09-2009 at 3:09pm
other thing about this I how firm is all the assy fixed to the hull.. I wouldn`t like the plug to come loose with all the thread housing, causing hull damage..
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: March-09-2009 at 3:23pm
Yep, gotta work on that hull drain. If you don't have the T-handle most of us are used to, you might try tapping a cold chisel into it at the shallowest angle you can work with. The only thing is that you'll probably have to replace the plug afterwards.
There is a cheap drill operated pump available here for about $6 US. The one I'm familiar with is set up for garden hose fittings so you'd have to make connecting fittings.
Get the girls back in the boat and it might just loosen up!
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: March-09-2009 at 3:36pm
Good idea there!!! i`ll try that one and let you know the results!!!1
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: March-09-2009 at 4:01pm
sounds like someone has mismatched the threads a stright pipe thread t-handle/orginal with standard tapered pipe thread plug most likely galvanized at that doesn't go well witht he brass housing. On mine the base/housing was bolted to the hull yours might be glassed, in that case, cranking on it to hard might cause problems down the road.
don't recomend the chissle trick that's just going to make it worse by expanding it and locking it even tighter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: March-09-2009 at 4:10pm
Only if it's tapped in the wrong direction! LOL
All I'm saying is that I've seen a properly applied thong move mountains.
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: March-09-2009 at 4:14pm
Cris from what i see housing seems to the bolted from the outside bottom of the boat. From inside you can see the screws locked with the little nuts...
Maybe I can unscrew all the housing along with the plug and benck work at home.....
Then reinstall everything using a good sealand adhesive...
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: March-09-2009 at 4:22pm
Better look underneath...I bet those screws are bedded in the glass(below the gel). Mine has the same set-up...I think the screws are in the threaded fitting and not available from below.
1988 BFN-sold
62 wood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 62 wood Quote  Post ReplyReply Direct Link To This Post Posted: March-09-2009 at 4:24pm
My old 64 doesnt even have a drain plug. I use the cheapo pump that chucks in a drill. It can still be a mess, holding the drill and keeping two hoses from flopping around. Make sure the container your pumping into is large enough for all the oil. ( I use two, one-gallon plastic containers)
   Warm engine definately helps, I put a bunch of old cardboard and carpet scraps over the boat carpet. I dont care how careful, seems like theres alway a little oil spillage.
I like Gregs idea...get more pics of the girls in the boat.....
Not sure it does any good on the plug, but sure warms up OUR winter days!
64 American Skier
62 Classic..
73 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: March-09-2009 at 4:25pm
The chisel meathod is only meant to be a 'polite' impact wrench...don't use a BFH!
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: March-09-2009 at 4:27pm
C'mon man...if he wraps a thong aroung the fitting in the right direction...
1988 BFN-sold
lewy2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lewy2001 Quote  Post ReplyReply Direct Link To This Post Posted: March-09-2009 at 10:17pm
Kapla you should have something like this in your 90. It is exactly the same as my 89.
Thru Hull & T handle bung
It also had a square plug frozen in the thru hull fitting like yours. It was impossible to get it unfrozen while still attached to hull. Remove the thru hull fitting just 4 s/s bolts with nyloc nuts on mine. This makes it much easier to hold the fitting in the vice and get that frozen plug out.
They had used a galvinised plug which had frozen real solid needed to apply a bit of heat to get it out. I ordered only the t handle fitting then as the threads in the thru hull fitting were fine.
Like TRBenj said when ever the boat is out of the water the bung should be out. It drains any water and we know the pre 93 hulls like to be kept as dry as possible.
89 Ski
Brady View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brady Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2009 at 12:02am
Greg,
Thong move mountains...Great image!
Charlie
Three Lakes, Wisconsin
69 Barracuda
quinner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2009 at 12:29am
Originally posted by kapla kapla wrote:
I start with 100 strokes only 1 quart is out!!!
youve gotta get that unstuck!
so I canīt use it.
I wanted to pump
If you cant get it off by hand, get some leverage on it. Pipe wrench, vice grips- anything. It should come if you hit it. Spray some penetrating oil on it first and let it soak for a few days.
jbear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbear Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2009 at 2:31am
You took the words right outa my mouth Quinner. Gotta be some sort of record...so many opurtunities in one thread.
john
"Loud pipes save lives"
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2009 at 10:46am
LMAO!
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2009 at 1:44pm
so I canīt use it.
I wanted to pump
Very good iīm still crying
Back to the boat I got the thruhull out... it was easy, I just needed help from below to hold the screw in order to prevent it to spin with the nut when unbolting.....
Then whith a bench morse and a good adjustable plier (stilson here? the ones used on plumbing) we got it out.
this was mounted
the plug head warped thats why it was impossible to get it out...
and this are diferent 3/4 bronze plug I bougth to replace the old one... i'm not sure which one is best....
the old one is solid and the new are hollow...
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2009 at 1:47pm
No T handles available here... I was thinking on getting the one from skidim but shipping and customs will kill for that.. and this plugs i got here all cost me $5...
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2009 at 1:48pm
Sebastian, for god sakes get a proper one with a T-handle so you dont have to go through this whole thing again next time!
Lewy linked to the $30 part from SkiDIM above.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2009 at 1:52pm
yeap they sell the t handle for $9..
i will try at local parts here and if not I get the one from skidim...
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2009 at 2:07pm
Seb,
You should have a local welding shop down there. Have them braze or weld on a T handle to one of the new plugs you bought. Bilge drains don't need to be wrench tight. There's very little pressure on them so the T handles work great hand tight.
Brass to brass can be TIG welded. Bronze to bronze depending on the exact alloy should be brazed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2009 at 2:28pm
Yes I was also thinking about doing that...
And one more when putting the housing back to the hull, which adhesive sealant is recomendable the 3m 5200?
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2009 at 2:31pm
i think the housing is brass, are the bronze plugs ok or should i get brass plugs?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2009 at 2:47pm
If you're going to have a T handle welded on, ask your welder which he would prefer. It's been a few years since I welded the brass windshield brackets together for my Atom but I seem to remember the Tig setting are the same as aluminum. AC current and continuous high frequency.
Yes on the 5200 for bedding the housing back in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2009 at 2:58pm
Brass is a copper bronze alloy?
