  New Posts New Posts RSS Feed - PCM proboss GT-40 5.8L, what sized fuel injectors?
zimm17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote zimm17 Quote  Post ReplyReply Direct Link To This Post Topic: PCM proboss GT-40 5.8L, what sized fuel injectors?
    Posted: July-10-2010 at 6:59am
The above engine was just resurrected from a 2 year slumber. Fuel was bad, replaced. New plugs, wires, rotor. new fuel filter. Lower fuel pump was toast and sent white corrosion into fuel system. I think the injectors are clogged. It runs great until 3000rpm then just stubbles. I was thinking I could put a set of ford motorsport injectors in it for about how much it will cost to get the stock ones tested ($200 for that).
What size are they?
horkn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote horkn Quote  Post ReplyReply Direct Link To This Post Posted: July-12-2010 at 2:36pm
I think there are 24 lb/ hr injectors on a PCM gt40.
Doing the computations to determine injector size says 24 lb ones are proper.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: July-12-2010 at 2:43pm
Originally posted by JoeinNY JoeinNY wrote:
Then I figured it was time start tearing down the pile of debris that used to be an engine and sort out what I could about the mysteries of the GT40 engine so I could toss the junk and get some space back..
24 lb ford fuel injectors
Post Options Post Options   Thanks (0) Thanks(0)   Quote zimm17 Quote  Post ReplyReply Direct Link To This Post Posted: July-12-2010 at 4:36pm
Thanks! After some researching, it looks like ford has changed to an upgraded 24# injector- the Ford Racing M-9593-AA302. Found a new set of 8 for $149!
PAPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PAPA Quote  Post ReplyReply Direct Link To This Post Posted: July-12-2010 at 9:51pm
Ford Racing has two different 24lb kits available. The M-9593-AA302 has the blade type pins on the injector and the M-9593-LU24 has the needle style pins on the injector. Make sure you order the ones that match your old injector style.
jhersey29 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhersey29 Quote  Post ReplyReply Direct Link To This Post Posted: September-27-2014 at 7:21pm
397-M-9593-LU24A and 397-M-14464-A8 seems to be the current setup from Ford Racing Parts
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhersey29 Quote  Post ReplyReply Direct Link To This Post Posted: September-27-2014 at 8:07pm
I was comparing the specs between the M-9593-AA302 and 397-M-9593-LU24A
The Injector voltage offset as a function of battery voltage is different. Will this cause problems? If one responds quicker won't more fuel flow out if the injector is left open for the same amount of time? Less dead time on the injector
M-9593-AA302
VBAT Voltage Offset
volts) (ms)
6 2.273
8 1.420
10 1.005
11 0.863
12 0.751
13 0.666
14 0.579
15 0.504
397-M-9593-LU24A
VBAT Voltage Offset
volts) (ms)
6 4.453
8 2.234
10 1.527
11 1.297
12 1.127
13 0.997
14 0.874
15 0.785
Treybizttu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Treybizttu Quote  Post ReplyReply Direct Link To This Post Posted: December-03-2014 at 12:07pm
Bumping an old thread to ask a question.. It's next to impossible to find the 24lb injectors with the
Jetronic®/ Minitimer ® and that was what my GT40 came equiped with. Anybody have a source for new injectors with the "older" connector?
They sell little plug in adapters but I'm not sure I trust that.
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: December-03-2014 at 12:46pm
Go to the auto parts store and ask for injectors for a 95ish F250 with a 460.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Treybizttu Quote  Post ReplyReply Direct Link To This Post Posted: December-03-2014 at 12:54pm
Oreilly and Autozone want $70 each injector :0... The FMS kits can be had for less than $250 for a whole set.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhersey29 Quote  Post ReplyReply Direct Link To This Post Posted: December-03-2014 at 1:02pm
The ford adapters are fine. You fill them with dielectic grease that comes with them. Height is not an issue they clear fine. They have good water seals on them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Treybizttu Quote  Post ReplyReply Direct Link To This Post Posted: December-03-2014 at 1:13pm
http://www.latemodelrestoration.com/item/M9593LU24A-K/Mustang-Ford-Racing-24lb-Fuel-Injector-Kit-w-Adapters-86-04
Something like this?
The body looks different than mine but from what I've read the long/skinny ones are just the updated version of what I have...
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhersey29 Quote  Post ReplyReply Direct Link To This Post Posted: December-03-2014 at 5:46pm
http://www.buyfordracingfromdpm.com/ford-racing-24-lb-hr-fuel-injector-set/
Yes. I got mine from buy ford racing. $20 less. You pick the option to add the adapters. $179 with out adapters, $199 with. The body is different and they have 6 very small holes instead of 4. They vaporize the fuel a bit better than the older version.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Treybizttu Quote  Post ReplyReply Direct Link To This Post Posted: December-03-2014 at 6:38pm
Awesome thank you... The ones in there are a clogged up mess and two were cracked on the top from the PO messing with the motor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: December-03-2014 at 7:28pm
Link to Ford racing
Post Options Post Options   Thanks (0) Thanks(0)   Quote Treybizttu Quote  Post ReplyReply Direct Link To This Post Posted: December-05-2014 at 11:35am
Thanks all,
Ordered and on the way.. I should have a pile of new parts in the next week or so
