  New Posts New Posts RSS Feed - Ramlin Trailer modification Bow stop
dcoll View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dcoll Quote  Post ReplyReply Direct Link To This Post Topic: Ramlin Trailer modification Bow stop
    Posted: August-27-2010 at 7:21pm
I have a 2001 Ramlin Tandem axle trailer. I am tire of the bow stop ripping my boat cover and deforming my rub rail. Has anyone removed the bow stop to add a under rub rail stop? Thanks
1997 Super Sport Nautique
SN206 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SN206 Quote  Post ReplyReply Direct Link To This Post Posted: August-27-2010 at 8:17pm
Post a pic. But, if it is whast I'm thinking of, why are running the boat all the way up to it?
M3Fan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote M3Fan Quote  Post ReplyReply Direct Link To This Post Posted: August-27-2010 at 8:30pm
You kinda have to. For starters, it structurally stabilizes the trailer with the boat on it. Without, you get a lot of bounce since the trailer is a 2-bunk "wishbone" trailer. 2ndly, even if you do not initially get it up to the bow stop, just the action of driving the trailer around will cause the boat to settle into the bow stops.
2016 SN 200 OB 5.3L DI
https://forum.fifteenoff.com
Air206 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: August-27-2010 at 8:40pm
Do you have enough space on tongue for a Bow-eye stop to be added? Is yours like my Ram-lin and has a winch strap through the bow stop pillar?
Perhaps a bow-eye stop originating from the area of the turnbuckle attachment may be the ticket.
Post Options Post Options   Thanks (0) Thanks(0)   Quote behindpropeller Quote  Post ReplyReply Direct Link To This Post Posted: August-27-2010 at 8:51pm
Your putting the trailer too far into the water when loading it.
Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote dcoll Quote  Post ReplyReply Direct Link To This Post Posted: August-27-2010 at 9:07pm
behindpropeller- i have to bring close enough to bow stop to be able to attach turnbuckle. I does not matter how far back i load it. I drive thru the mountains for 3 hours. I need something to stop it from moving forward. I do not have a winch. Just bow stop and turnbuckle. A v type stop at the hull would be nice. I was just wondering if anyone else has done this mod. How do i post a pic?
Post Options Post Options   Thanks (0) Thanks(0)   Quote behindpropeller Quote  Post ReplyReply Direct Link To This Post Posted: August-27-2010 at 9:11pm
If the boat is still floating level in the water when you hit the bow stop then you have the trailer too deep in the water. Trailer fenders should be 1-2" above the waterline when loading.
Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: August-27-2010 at 9:21pm
Tim:
This isn't a loading issue. If I load with the rail 4" from the stop and the turnbuckle is connected and tightened, the boat will walk forward. This stinks because the turnbuckle begins to push into the gel and the bow gets up/down travel. I think this is more of an issue with trailers that have the turnbuckle attached at the base of the bow stop pillar than ones which have a separate (and farther aft) attachment point.
Our hilly terrain makes the same thing happen.... and Dan's Boat is heavier than mine.........
Post Options Post Options   Thanks (0) Thanks(0)   Quote dcoll Quote  Post ReplyReply Direct Link To This Post Posted: August-27-2010 at 9:30pm
Thank you Air 206. You are exactly right about the turnbuckle. It is mounted at the bas of the bow stop. I just want to be able to see pics of a hull stop installed on a trailer like mine. I have a pic but i do not know how to post. It seems that no matter where the turnbuckle is mounted the boat will still slide without a stop or jam the turnbuckle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote behindpropeller Quote  Post ReplyReply Direct Link To This Post Posted: August-27-2010 at 10:34pm
Originally posted by Air206 Air206 wrote:
Tim:
I didn't say to load the boat 4" from the bow stop. Drive it to the bow stop. If the trailer is too far in the water and you drive it to the bow stop it will rotate and pull the rub rail.
Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote SN206 Quote  Post ReplyReply Direct Link To This Post Posted: August-27-2010 at 10:46pm
Still leave it 4" from the bow stop then weld in a "V" on the frame of the trailer. That way the boat will ride / load better, the bow stop will be used for it's purpose, and you won't tear up your cover. Do a search for "posting pics" and several will come up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dcoll Quote  Post ReplyReply Direct Link To This Post Posted: August-27-2010 at 11:22pm
Maybe i did not explain this correctly. I load my boat and not touching the bow stop. I attach the turnbuckle and do not over tighten. I put cover on and drive home. By the time i get home the boat has slid forward hitting the bow stop. The rub rail gets deformed after the boat slides and the rub rail rubs a hole in my $760 custom cover from bouncing down the highway. The turnbuckle's position will on keep it from sliding off and NOT from sliding forward to the bow stop. I need to have a "V" stop welded to my trailer. I was hoping that someone had this problem and corrected it. Maybe I am the only guy with this issue. Still cannot figure out how to insert pics.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SN206 Quote  Post ReplyReply Direct Link To This Post Posted: August-27-2010 at 11:55pm
1. Look at the bottom left of the "last" post.
2. You will see a blueish gray box that says "Post Reply", click on it.
3. A new post box will appear, on the top you will see a box with
   a tree and blue arrow.
4. Click on said box and find location of photo to upload.
5. Note: you may ahve to resize photo to be less thamn 500 meg.
I believe I understand your situation and think welding in a "V" is the right thing to do. We'll have a better idea when pic is posted
Post Options Post Options   Thanks (0) Thanks(0)   Quote dcoll Quote  Post ReplyReply Direct Link To This Post Posted: August-28-2010 at 12:21am
Here is a pic of my trailer
Post Options Post Options   Thanks (0) Thanks(0)   Quote dcoll Quote  Post ReplyReply Direct Link To This Post Posted: August-28-2010 at 12:28am
My boat on the trailer
Post Options Post Options   Thanks (0) Thanks(0)   Quote SN206 Quote  Post ReplyReply Direct Link To This Post Posted: August-28-2010 at 12:39am
Looks like a poly roller to "V" would work perfect.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dcoll Quote  Post ReplyReply Direct Link To This Post Posted: August-28-2010 at 12:44am
Thank you. Now you say mount it so the bow rub rail is 4" from bow stop? Will the boat bow even hit the bow stop?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dcoll Quote  Post ReplyReply Direct Link To This Post Posted: August-28-2010 at 12:45am
Mount above or below bow eye? i would assume below so turnbuckle can attach.
Fibersport View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fibersport Quote  Post ReplyReply Direct Link To This Post Posted: August-28-2010 at 12:45am
This might be a dumb question but is your trailer level when you tow it? I realize that things will always walk forward when towed but if you're lower in front it would probably make things worse.
And mount any rollers above the bow eye, otherwise the boat will hang up on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SN206 Quote  Post ReplyReply Direct Link To This Post Posted: August-28-2010 at 12:47am
Yes, when it needs to. Like when some a-hole pulls out in front of you and you don't want to become intimate with your boat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SN206 Quote  Post ReplyReply Direct Link To This Post Posted: August-28-2010 at 12:53am
Below and further back, somewhat below the boat in the v-part of your hull.
NAUTIQUEjunky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NAUTIQUEjunky Quote  Post ReplyReply Direct Link To This Post Posted: August-28-2010 at 1:04am
I always floated my boats on the trailer by hand. I would just barely let the rubrail touch the bowstop. It would still slide forward on the way home, so i would loosen the pinch bolt to move the Bowstop forward so it would not compress the rubrail and deform it..
1977 MasterCraft Stars&Stripes
1994 Ski Nautique
2000 Super Air Nautique
1986 Ski Nautique 2001
1999 Sport Nautique gt40 current
Post Options Post Options   Thanks (0) Thanks(0)   Quote dcoll Quote  Post ReplyReply Direct Link To This Post Posted: August-28-2010 at 1:16am
I tighten the pinch bolt to push the bow stop aft so that when I get to boat ramp, I can loosen so that I can get my boat cover off. I have forgotten to tighten and my boat slides forward and I cannot remove cover.
To respond to other about my boat trailering low in the front. You need a little more weight in the front to keep from swaying.
No one else must have them same trailer. The only solution that I see is a hull stop. I have tried everything.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SN206 Quote  Post ReplyReply Direct Link To This Post Posted: August-28-2010 at 1:20am
MartyMabe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MartyMabe Quote  Post ReplyReply Direct Link To This Post Posted: August-28-2010 at 2:10am
Gonna use this for the 66 Skylark trailer.
Do something like, cutting your bow stop down, put an angle to the tubing and move your stop back to those holes behind where it's attached now. Follow?
66 Skylark
93 SN
If you're not living in NC, you're just camping out!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: August-29-2010 at 1:28am
You have a flip up trailer tongue, right? .. Similar to Marty Mabe's 1993 SN Trailer...
I would be mindful of the "up" position of the tongue so that the welded-on V doesn't interfere............ keep that flip action useful....
quinner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: August-29-2010 at 1:56am
You need a more downward pull on the bow eye. Put an eye bolt in one of the holes on the flipping tongue piece and move the turnbuckle there. Holding the nose down will keep the bow from bouncing. Trailering with the cover on will damage it and the boat.
harddock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote harddock Quote  Post ReplyReply Direct Link To This Post Posted: August-29-2010 at 10:05am
I have had the same problem and usually I0 notice it most when towing long distances where you might have had to brake hard at some point.
I run a short ratchet strap from the boweye back through two factory welded rings about 18" aft of bowstop (yes, mine is a Ramlin) and snug it up. This seems to help so far.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dcoll Quote  Post ReplyReply Direct Link To This Post Posted: August-29-2010 at 11:20am
Martymabe, your boat and trailer are awesome. Sooo cool. I want to thank all of you for giving your time and expertise. Out of all the suggestions, I will first try harddock's for now. This is a great idea without doing any modification to the trailer. I like to keep the trailer original. I feel like a cheesedoodle that I did not think of this. Once again thank you guy's for everything. I am going to the lake this weekend and hope to get those straps. I will let you know how it turns out.
jhiestand View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhiestand Quote  Post ReplyReply Direct Link To This Post Posted: August-29-2010 at 11:56am
dcoll -- is your cover a snap on and if so, have you considered having your cover altered so it doesn't contact the crash pads when it's on? I have a custom cover on mine and it has notches that allow me to put the cover on w/out contact of the crash pads. I know this doesn't address the rub-rail deforming issue, but it's probably a lot less effort to have done.
