how do i remove anti-siphon valve |
aquaman766
Newbie Joined: May-02-2010 Location: Gasport, N.Y. Status: Offline Points: 20 |
Posted: July-12-2011 at 7:53pm |
My fuel line is clamped to a 90 deg. fitting at the tank. I assume this is the anti-siphon valve. There is a large nut that looks like it holds something inside the tank. If i remove this large nut will i lose a part in the tank? How do i inspect the anti-siphon valve? Do i need to pull a long part out of the tank? I only have a few inches between the top of the tank and the boat hull. Any information would be helpful. thanks
aquaman766
Oh well, i guess i'll just remove the nut and hope i don't lose parts into the tank. I'm still not sure if what i'm removing is the AS vavle.
Ron,
Nothing will fall into the tank. Yes, that fitting on the top is the anti-siphon. There's a ball check inside that you want to take a look at. |
aquaman766
thanks Peter
