  New Posts New Posts RSS Feed - Removal of Ski Pylon on 1989 SN 2001
tjamesbo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tjamesbo Quote  Post ReplyReply Direct Link To This Post Topic: Removal of Ski Pylon on 1989 SN 2001
    Posted: May-02-2012 at 6:07pm
I could do with the ability to temporarily remove the ski pylon on my 1989 2001 Nautique . Reason for this is that I have a Joystick Pylon fixed to it (tower height sleeved pylon extension ) which seems to be on very tightly, as such I cannot remove the joystick Pylon In order to get the boat in my garage. There are 4 Bolts at the Bottom of the Ski Pylon is it a case of loosening these and the Pylon lifts out, and slides back in again. Could it be that simple ??
Thanks Boyd
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: May-02-2012 at 6:09pm
There is a female socket glassed into the hull. The bottom of the pylon slides in and has 1 bolt front to back holding it down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tjamesbo Quote  Post ReplyReply Direct Link To This Post Posted: May-02-2012 at 6:34pm
here is a piccie of my set up
what do these nuts do? It looks like a double U bolt setup????
where is the single Bolt ? below this
how do i get access to the other side of the Bolt It must be under the sealed bit of the Floor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: May-02-2012 at 6:47pm
The are U-bolts (2, horizontal). All you need to do is loosen those. Look all the way down at the bottom of the hull for the front to back bolt. It goes through the pylon and pins it into a cup that is molded into the bilge. You need to completely remove this bolt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tjamesbo Quote  Post ReplyReply Direct Link To This Post Posted: May-02-2012 at 6:54pm
Thanks Hollywood
lewy2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lewy2001 Quote  Post ReplyReply Direct Link To This Post Posted: May-02-2012 at 10:48pm
James it looks as though your high pole has worked its way right down over the bend in the original ski pole. I think this is why it is hard to remove from original pylon. There is also a combination of tape and protection mesh that needs to be investigated.
Does the high pole have a through bolt with ski hook on the back that sits on top of the original pole limiting how far it can slide over original pylon? If not I would fit one, makes removing the high pole much easier than having to pull the pylon every time
89 Ski
