Pinstripe & decal removal |
velde99
Platinum Member Joined: November-04-2012 Location: Tampa Florida Status: Offline Points: 1108 |
Posted: April-25-2013 at 1:32pm |
Anyone know of effective way to remove old pinstriping from a 1991? It is old and brital- I am removing it, but is breaks off every inch or so and is leaving the old dried out "stickum" on the hull. Want to get it off as quickly as possible without damaging the hull.
cphase
Gold Member Joined: May-11-2010 Location: Newnan, GA Status: Offline Points: 795 |
Oceanfisher1010
Newbie Joined: April-25-2013 Location: St. Aug, FL. Status: Offline Points: 1 |
I just removed the decals and pin striping on my 1989. A heat gun is a must. Removes quickly and easily. Also, leaves very little adhesive. You can try a hair dryer on its highest setting. It may take more time to heat the pin striping with a hair dryer.
I bought my heat gun for $30 at Ace Hardware. |
tbeard
Senior Member Joined: April-26-2012 Location: Fort Worth TX Status: Offline Points: 379 |
I bought a Harbor Freight heat gun for $15.00. It works but the pin strip still takes some time due to breakage. You have to get the decal the right temp...soft enough to pull off but not so hot that it almost melts.
Clean glue off with acetone. |
Thanks.......Tom
Kiteboarder
Groupie Joined: February-10-2013 Location: League City Status: Offline Points: 53 |
3m stripe off wheel works great, used mine today. I ordered it off Amazon after one of my neighbors that works for a body shop told me about it. http://www.amazon.com/3M-7498-STRIPE-WHEEL-W-ARBOR/dp/B00063VT0G/ref=sr_1_1?ie=UTF8&qid=1366939757&sr=8-1&keywords=3m+stripe+off+wheel
Kiteboarder
Did transom in about 10 mins!
For the convenience of all, here's a proper link |
