MSD Marine distributor |
Post Reply | Page 12> |
Author | ||
backfoot100
Posted: April-08-2014 at 6:46pm |
As most of you know, I'm a huge fan of MSD distributors and ignitions as I've been running one in my boat for well over a decade. I had it installed in my engine before my rebuild and reused it after.
MSD is good but you needed the distributor and the ignition box to make everything work in perfect harmony. I was on MSD's website and I found this . It's a ready to run distributor that includes the ignition box built into the distributor!!! No more stand alone box to hook up. Just drop the distributor in the engine and hook up three wires. Includes a completely adjustable advance setup which I can tell you is a breeze to adjust. I know several here are DUI fanatics but this MSD unit looks to be the cats nuts and available for SBF and SBC marine engines. Anyone looking to replace a distributor should definitely give this some consideration. |
Eddie |
Eddie, where do you see the application for the SBF (presumably 302 and/or 351w)? I only see the 351C/460.
Waterdog
It's cool to see a new marine distributor. I looked around the web site, didn't see any SBF Windsor stuff STD. or R/R ? |
Dreaming
the $400 price tag looks pretty nice compared to the SKIDIM kit for my protec conversion.... I'll have to keep a look out for the 351w version
backfoot100
Damn Tim, I just saw the 351/460 and assumed it was the Windsor. That's what I get for assuming. Think it might be a typo? Seeing as there are probably very few 460 marine engines out there in the overall scheme of things and even fewer 351C marine applications (like none that were ever marinized that I'm aware of) it just doesn't make sense to me that they have a distributor for those engines and not a Windsor. Maybe those engines use the same distributor by default? |
Eddie |
JoeinNY
Same distributor, different gear for the small block as the big block, why msd doesnt sell it with the right gear all ready to go... well cause they hate me, or because the market is in big block jet boats that race and spend big money on go fast parts. If you go with a vic jr intake manifold though be advised the ready to run distributor is too big and you need to go with the older school distributor and box setup (and you will need to grind a little bit on both the intake and distributor body).
*edit* that distributor works with a 351W small block with a gear change it does not work with a 302w... |
jbear
uhh..ski partner..do I need one of these? And if so..will you put it on? If I remember correctly you have a "MDS" thing mounted to your motor box..which is somewhere I never go without adult supervision.
john edit: just went to your link..how hard can this be? only 3 wires! |
"Loud pipes save lives"
kytom2
Gold Member Joined: July-25-2007 Location: Maysville Ky Status: Offline Points: 698 |
That's 2 too many for you Jbear!
wholman
Newbie Joined: December-13-2013 Location: Vero Beach, FL Status: Offline Points: 14 |
The distributor that you're talking about does have a Cleveland gear and as was said before all you have to do is swap the gear for windsor gear and you're good to go. It does run fine without the ignition box but if you use the msd box you gain the multiple sparks. With the just the distributor you get single sparks. I've used my mine with and without the box and it works great either way but I have the box hooked up in the boat because I like having mtiple sparks. Better idle and more power down low is what they say.
Eddie here is a picture of one in a Donzi,looks professionally done so there must be more of them. Holman Moody filter assy,could be possible they marinized them? I would guess it's advantage would be in high rpm operation so ski boats would be out? |
In John's defence,it's not the number of wires he'd have trouble with, it's what he'd do with that one extra wire after he's spliced up the pair |
Riley
Here's a Donzi with a Boss 302 engine. DHart and I looked at it last fall and we didn't know what we were looking at, but the other day I ran into someone I knew that said they were the 2nd owner of that boat, and they said the original owner swapped out the original H/M engine for a new crate Boss 302 engine. This boat was priced too high last fall at $16k, but has since been lowered to $9900. Are these Cleveland heads? It's definitely different than a regular 302.
halfnelly
Senior Member Joined: January-14-2013 Location: Maitland, FL Status: Offline Points: 253 |
Not sure if any OEMs marinized them, but the Aussies have been doing it. Clevelands are basically as plentiful there as Windsors are here. I know there are some companies that specialize in marine conversion parts for them, such as these:
http://www.kmrolco.com/Price_List.html http://www.cassellmarine.com.au/c/217788/1/velvet-drive-conversion.html |
In simple terms Bruce a Boss was a 302 with Cleveland heads.The valves were canted in the castings \ / as opposed to a Windsor's | | to help with flow but in reality the blocks were stronger castings too for instance the core plugs were threaded in rather than the Windsors press in ones. You can put Cleveland heads on a Windsor motor but it requires machining and a special intake.
halfnelly
Putting Cleveland heads on a Windsor block (a Clevor) used to be the hot setup before everyone started making aftermarket Windsor heads. The big valves and sewer pipe-sized ports make for a pretty high winding motor. They're not too common nowadays because the Windsor heads have gotten so good it's not worth the extra effort, especially just to use heavy iron castings.
GottaSki
Grand Poobah Joined: April-21-2005 Location: NE CT Status: Online Points: 3359 |
Thats cartainly looks like the real deal, as Cleveland heads' valve covers have 8 bolts vs 6 for the Windsors.
One potentially awesome option is the Kaase P38 canted valve heads, the ports are made to match std windsor configuration. |
River Rat to Mole |
backfoot100
I just talked with MSD tech support and he confirmed what Joe and wholman have stated. Change the gear and the 351C/460 unit would work in the Windsor. I asked if there has ever been discussion about making a Windsor distributor available and he said they ask the question to R&D constantly. The R&D guys must know something we don't. Maybe you Ford guys need to come to your senses and get into bowties
Still would be a nice replacement even if you need to change gears. Definitely worth looking into anyway. |
Eddie |
backfoot100
I could talk you through the three wires easy enough. As soon as the distributor gets pulled and you see that gaping hole on top is when I don't want you anywhere near it...LOL Your boat runs too good with points. If the distributor ever decides to give up the ghost, we'll talk. If it aint broke, don't fix it. |
Eddie |
jbear
now this is the kind of engine talk I can understand.... 9am saturday morning date? john |
seacamper
Platinum Member Joined: June-24-2010 Location: Florida Status: Offline Points: 1056 |
So Eddie,
I STILL have the minor stumble under a heavy load in the 75 SN. I have got to think that it is the distributor/points at this point, and after checking compression, timing, dwell, etc, I am thinking it is weak spark induced by 40+ year old distributor/weights/springs/moving parts. What do you think about this upgrade? MSD |
1980 Ski Nautique Boat Bar
1988 Mastercraft Tristar Open Bow 1988 Mastercraft Tristar Closed Bow 1969 Seacamper Houseboat 1986 Harris Pontoon 2004 Seadoo GTX SC + Flydive Xboard 1999 Adventurecraft |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11061 |
Hi I'm not Eddie (he's better looking than me ) but if you read back thru this thread and look at your link, you'll see that it has the wrong gear for a 351 Windsor. It's got a gear for a LH rotation 351w/429/460 Ford. You would need a gear for a RH rotation 351 Windsor. Pretty sure MSD doesn't make one of them You'll probably have a few people telling you to get a DUI distributor cause they think it's the best thing since sliced bread and then Pete will jump in and make a point about keeping points in it. KenO |
seacamper
Ahhhh. I will look at the DUI product and listen to Pete's sage advice.
seacamper
So I am assuming I would order the "351 W 7000 rpm Reverse Rotation" distributor, and it will be a crap shoot on whether it will fit??
DUI I am interested in "vabration proofing" my distributor. The DUI Advantage Virtually Waterproof Vabration Proof Fully Electronic One Wire Hookup 7000 and 10,000 RPM Versions |
I bet the picture above looks an awful lot like your engine. Hard to tell from your picture but it looks like there would be plenty of clearance between the distributor cap and the thermostat housing/hoses, so not so much of a crap shoot as a PCM engine. Maybe it's even vibration proof too but yea you should be interested in vabration proofing it too Kinda reminds me of the Beach Boys Good, good, good Vabrations . |
backfoot100
Whew, back from a week of vacation and trying to get back into the routine. +1 on what Ken said. The MSD would work but you'll need to find a RH gear and MSD doesn't offer one. The good news is that we have this local machine guy that's pretty good whom you also know. I would bet my next paycheck that he can make your old gear fit perfectly on any dizzy you decide to put in. MSD or DUI. That is unless the old gear is damaged in any way. I'm pretty biased toward the MSD but the DUI is obviously very proven. The only plus I see with the MSD is that the advance curve is completely adjustable to how you and the boat want it. The DUI isn't. I think the MSD would probably not experience the diameter fitment issues that several here have experienced either. If you're willing to be a test mule and knowing we have a good machinist at our disposal, I'd be very willing to help you help you try one out. That is a bummer about the hesitation. I know you've tried two or three different carbs, a complete tune up and checking over everything else you can think of. |
Eddie |
First of all, I'm not convinced the dizzy/points are your source of hesitation out of the hole. That is more likely to be a fuel issue from my experience... And I know of many points boats that jump out of the water.
That said, ignition upgrades can be nice if your dizzy is getting a little sloppy. I have 2 DUI's and am a fan of their performance and simplicity. Joe and Eddie both have awesome running boats so MSD is a great option, too- if you can figure out the gear. Regarding the curve, Eddie may have been talking about curving the advance at home- though j don't see why you couldn't do the same on a DUI with standard HEI parts. Davis can curve to whatever specs you wan when you order. |
I think the same thing as TRB on this but it sounds like you want a new distributor. May not help but it can't hurt. |
seacamper
I am getting a bit worn out tweaking the carb. I will go through it again. Sigh.
Duane in Indy
I had a stumble when I would give it hard throttle from idle. Rebuilt carb knowing it was the accelerator pump. Hmm, same stumble. Even switched to another carb I had. Same stumble. Hmm again. Check timing and found that initial was OK but the total timing was not consistent. It would either not come in or come in late. Went to MSD dizzy and it was fixed. Had to replace gear with a new one as stated before. Three wire hook up was a breeze. One to coil, one to ground, and one to key 12 volt hot. Total advance is adjustable also. One can argue points or EI all they want but try to buy a new internal combustion engine with points. Good luck with that. Everybody changed over for a reason.
(Am not a fan of EI conversion modules that you drop into a points dizzy. They tend to be flakey) This should open a can of worms. |
1978 Mustang (modified) |
Hi Duane
I think that can has been opened a hundred times before this. It's like Ford vs Chevy What's the best oil What's the best oil filter What's the best coil Gilligan or Mary Ann And the list goes on and on KenO PS Mary Ann gets my vote |
