  New Posts New Posts RSS Feed - stern light
stern light
AAM196 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AAM196 Quote  Post ReplyReply Direct Link To This Post Topic: stern light
    Posted: August-10-2014 at 1:36am
What is the most common issues with stern lights? Mine goes on and off and I thing it is the base.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-10-2014 at 5:19am
Corroded contacts in the base.
Orlando76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: August-10-2014 at 9:37am
Being a newer boat and in PA, possible corrosion in base but I doubt it. My money is it in the contacts at top on light pole especially if its incandescent. My '06 Carolina Skiff lives in the saltwater. I'm on the original base but probably the third pole.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AAM196 Quote  Post ReplyReply Direct Link To This Post Posted: August-10-2014 at 2:07pm
Thanks I will take it apart to investigate... since it is windy and busy at lake.. and afternoon.. beers and boat tinkering time.
CrazyCanuck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrazyCanuck Quote  Post ReplyReply Direct Link To This Post Posted: August-10-2014 at 11:16pm
I rebuilt mine. You can drive out the back plug at the base that has the 2 plug contacts. Clean those up, and in my case I had to solder new wire from there to the light socket as well. Everything was bad on mine...lol
https://encrypted-tbn1.gstatic.com/images?q=tbn:ANd9GcRtW3vJrMHLdqBzndt9VX3oOpBuRopGlzKq9Ea7pAO7wnTuoD8E8g
DayTony View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DayTony Quote  Post ReplyReply Direct Link To This Post Posted: August-10-2014 at 11:39pm
if the base is cracked from stress does anyone still make replacements?
1988 Barefoot nautique-454
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2014 at 10:35am
Replacements should be easy to find. Nautiqueparts definitely has them, I'd imagine N3 and Christine's would as well.
Even at that, I think they are made by Perko and should be available many places. The CC dealer parts places would just have them organized by year etc. better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AAM196 Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2014 at 11:14am
Peter was right... just took some 400 grit to the contact points and some electrical grease.. problem solved.. then running late sets last night my boat wouldn't start... positive battery term was all crapped up... had to fix that but I want to find a pair of really nice battery contacts.
