  New Posts New Posts RSS Feed - Taped Stripes on 95 Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Topic: Taped Stripes on 95 Nautique
    Posted: October-16-2014 at 6:48pm
Just got the 95 back from Classic Craft in Sacramento, they fixed the damaged fiberglass perfectly. Not easy since the Black, Red and White were all needing some gel coat repair. Very happy with the glass repairs and color match. Invisible repair to my eye and I am picky.
The stripes on this boat are lined with smaller stripes about 3/8 of in inch wide that are tape not paint or gel coat. My damage ruined part of the tape in both red and white on the nose of the boat.
Do you guys know if this tape is still available. I am thinking of installing new tape all the way around. The shop spliced in the front 3 feet of the tape on the nose of the boat and I can see the splice and it bother me. If it is still available I want to replace all the tape.
It looks like it might be hard to lay this tape on and keep it straight but that is my plan.
Anyone else tackle the tape replacement?
This damage was from the Deer jumping out in front of our car while towing the boat home. The boat came forward over the front stop bars on the trailer.
BTW: The black rubber rub rail with a red insert on this boat was also damaged and they were going to replace it. The Red insert for the rub rail is no longer available. I liked the factory look so I tried to repair my old piece. I started with 400 grit sand paper, wet sanding, and sanded the rub rail and insert smooth. Sanded out the damage from the wreck. Then I dropped to 600 grit, then 1500 grit and then polishing compound. Took about 3 hours labor but it now looks factory stock with no visible damage.   The Rub rail looked like we took a cheese grader to it and the Red insert was burned with black rubber, looked like someone spun their tires down the red insert. Both turned out perfect.
Dreaming View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2014 at 7:25pm
Sounds like a good deal in the end.   Check with Zach at N3 on the tape, I believe he was able to get it in rolls about a year or so ago. if the shop was able to replace the first few feet, they may be able to get that tape through a local body shop supplier as well.   nice work on the rub rail!   I am glad you were able to keep the red insert, that look is really nice to me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2014 at 7:47pm
I tried to buy the tape from the repair shop. They say the colors are hard to find to match on repairs so they will not sell the old stock they have. They did say to check with Automotive Paint shops.
I am ignorant, who is Zach and what is N3? Sorry I will try and get up to speed. Hard to believe but the two scratches in the nose and trailer damage will be close to $5,000 when done. I wish I was good with gel coat work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2014 at 8:06pm
A good automotive paint supply should be able to match something from the 3M line.
I did my '85 myself not real hard takes a little practice. Key is to pull out as much as you can without streaching it then just slowly lay it on to the boat.
mark c View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark c Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2014 at 9:03pm
Heres the thread on pin stripes from about 18 months ago.
Pin Stripes
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2014 at 9:53pm
Gel work is easy Mark,you really would be surprised.It's the color match that is real tough much like car painting. Good thing about gel is that the color does not change as it "dries" so you can mix it dab some on and check your match. Here is some work I did to my Mustang,a previous owner had removed the console and controls and added a side mounted Morse. When I put it back as it originally was I had to fix that big hole in the gunnel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2014 at 10:08pm
jbear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbear Quote  Post ReplyReply Direct Link To This Post Posted: October-17-2014 at 2:30am
that color combo is still one of my all-time favorites Paul...beautiful job on that boat!
john
"Loud pipes save lives"
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: October-17-2014 at 5:08am
Nice repair on the boat Gary, Thanks to all for the tips on the tape.
I will have to order single rolls for this boat, my stripes are over 2 inches apart. Great information.
I have a white stripe above the black gel color and a red stripe below it as you see in the picture. This also shows part of the rub rail before it was sanded and fixed.
Happy to report the gauge in the gel coat is now looking good again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: October-17-2014 at 11:55am
Those stripes will actually be easier then mine were. My red stripe separated the gel colors but the black just ran an 1/8" above the red.
On yours just run the tape so that the gel color line is in the middle of the tape. The different colors of the gel are your line to follow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Posted: October-17-2014 at 2:18pm
Zach @ N3 is Phatsat67 on CCF I haven't bought anything from him yet, but others have had good service from their store, and he is an active forum member/$upporter
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: October-17-2014 at 4:00pm
Late to the party, all of the 1/4 inch stripe is still available from original manufacturer and color pallet.
I use a different company to reproduce the double pinstripes and they do nice work and have a very close match to most original colors.
The 150' x 1/4" rolls run about 19 bucks regular retail so apply a 10% off that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: October-17-2014 at 4:01pm
Side note: Paul's 85 is where it's at.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: October-17-2014 at 11:04pm
Thanks Zach can't wait to break her out next year with the new motor in it.
John
It's one of my favorite color combo's also.
NAUTIQUEjunky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NAUTIQUEjunky Quote  Post ReplyReply Direct Link To This Post Posted: October-20-2014 at 2:07pm
White Lake Marine has most all of the stripping avalible also.
1977 MasterCraft Stars&Stripes
1994 Ski Nautique
2000 Super Air Nautique
1986 Ski Nautique 2001
1999 Sport Nautique gt40 current
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-20-2014 at 2:42pm
Joey ,
This may be true but please consider how supportive Zach has been to the site. I don't recall anyone for White Lake EVER helping us! Plus, White Lake doesn't even sponsor the site!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: October-20-2014 at 2:47pm
Thanks Pete. Good to here from you . Things alright your way?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: October-20-2014 at 2:58pm
I love Zach and N3... But the white lake folks are top notch too! Townsend and the gang host our CCFan reunion every spring and treat us like kings with food, giveaways, raffle prizes, etc. No need for negativity!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: October-20-2014 at 3:04pm
It looks like the factory overlapped the tape on the nose. Is it possible to install the 1/4 inch tape in one piece so I would not have tape overlap at the nose? I would think it could be pulled around the corner without a cut but I have not done this job before.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-20-2014 at 3:40pm
Mark,
Overlap it like the factory did. The tape at the stem would be really stretched. Any place where the tape is stretched is a potential failure point. It may peel off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: October-20-2014 at 11:36pm
You'd have to be a magician to wrap it around the nose. Good luck!
Post Options Post Options   Thanks (0) Thanks(0)   Quote NAUTIQUEjunky Quote  Post ReplyReply Direct Link To This Post Posted: October-21-2014 at 1:57pm
Joey ,
Technically True Pete... Zach is a great guy and is currently researching repo dash panels for my 99 Sport.. Ive purchased parts from both places... The owners of White Lake are good People.. Ive never Bought a boat from them but Diane and her Son David always reconize me and speak at the boat shows in Raleigh. Im a firm believer also of supporting site sponsers and understand what you are saying.. But in todays world its all about Boat sales i guess?? and i guess PlanetNautique.com somehow is maybe an asset to them because all they really talk about is newer boats.. I personally wouldnt care for one of the modern boats with the $2500 intergrated display system.. I will stick with the what some folks call old stuff
1994 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: October-21-2014 at 9:30pm
Mark,
Thanks for the tips, now I need to identify the correct color and get some ordered for a Winter project. I understand my White Gel Coat is called Silver Cloud I don't know about the Red, I will check my Owners Manual and see if it is listed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: October-21-2014 at 9:59pm
I don't like the monthly 2500 payment or the bill when the 2500 display goes out
