302 HM Plug Wires |
NCH20SKIER
Grand Poobah Joined: December-16-2004 Location: United States Status: Offline Points: 2207 |
Posted: November-29-2014 at 4:30pm |
Anyone fought with the removal / install of these? Any tricks? Special wires with short boots? These are a PIA and knuckles!
'88 BFN |
Some silicone grease on the inside of the boots make removing them easy.
I replaced the ones on there so long ago I don't remember what was on there. But I used Accel 7mm solid core with short ish 90* boots that you cut the wires to length yourself and dielectric grease. If I was changing them now I'd use black ones. Who knows what is on yours after 40 some years
The black wire and boots look original! |
FYI Summit Racing has the marine Mallory flat distributor caps with brass contacts and rotors
here is the difference between 18mm plug standard heads and P heads standard heads- P heads and on the very right you can see part of a 90* plug boot |
NCH20SKIER
Thanks Gary. No doubt that I will have plenty of questions for you
'88 BFN |
