  New Posts New Posts RSS Feed - Water temp
Water temp
Sleepyone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sleepyone Quote  Post ReplyReply Direct Link To This Post Topic: Water temp
    Posted: May-10-2015 at 7:13pm
Ok rebuilt raw water pump and installed new high filler thermostat on a 87 ski Nautique with 454 engine. Temp is great running at cruising and any moving speed until u run in a no wake area or set idle then engine get hotter. Thermostats is 165. But temp gets up to 185 climbing if don't watch it.
Don't seem to have any leaks.   What you guys think ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2015 at 7:25pm
With a high temp at slow speed, typically you are sucking air but, temps will climb after a hard run and then idle. Why the 165 T stat?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sleepyone Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2015 at 10:47pm
Oops sorry. 145.   Degree ts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2015 at 7:56am
Only overheating at idle? Air leak between RWP and intake grate.
