  New Posts New Posts RSS Feed - Wont Start
Wont Start
brettmac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brettmac Quote  Post ReplyReply Direct Link To This Post Topic: Wont Start
    Posted: June-08-2016 at 4:21am
88 Dominique wont start after layup. I have tried to start the boat, replaced the plugs, coil and battery. It tries to fire, but wont catch all 8 cylinders. Motor was fogged with marvel mystery oil. What am i missing?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2016 at 7:23am
Good supply of fuel? How does the gas smell?
Post Options Post Options   Thanks (0) Thanks(0)   Quote brettmac Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2016 at 10:57am
Gas is coming from a fresh gas can. Boat was laid up with a full tank of premium non ethenol with stabil. Seems like she's pushing ton of gas down the carb. Belching black smoke and it looks like mystery oil can be seen in gas going down carb. She wants to start, but wont catch on all cylinders. Have cranked down the new battery twice without a start up. Just a lot of popping and farting. Getting discouraged. Help and thanks to all of you. Brett
Post Options Post Options   Thanks (0) Thanks(0)   Quote brettmac Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2016 at 11:00am
Did i use to much marvel mystery oil to fog motor and now it is inhibiting starting?
JoeinNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2016 at 11:04am
Unlikely unless its really full of junk, you might simply be flooding - try to hold the throttle all the way open and crank it over, don't pump the gas just hold it open and be ready to pull back on the throttle if it catches.
1983 Ski Nautique 2001
1967 Mustang 302 "Decoy"
Holeshot Video
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2016 at 11:05am
Plugs may be coated in oil, the first start after sitting and fogging can certainly be labored.
So you're pulling fresh gas from a remote can rather than relying on what's been sitting in the tank? Mine still won't start after layup on 6 month old gas, stabilized or not (no e-free here though). I'd give it the sniff test in any case- and give it a shot of fresh down the carb throat just to be sure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote brettmac Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2016 at 11:20am
Have tried all of that. Changed the plugs, fresh shot down throat, holding wide open, at idle etc. Nothing seems to make a difference.
JPASS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPASS Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2016 at 11:41am
Fuel fouled plugs? Are the plugs wet when you check them? If fuel down the carb won't get her to fire, maybe confirm that you have spark at all 8 plugs??
'92 Correctcraft Ski Nautique
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2016 at 11:42am
That's a good point.
I was also going to also mention, double check that you didn't accidentally jumble up the plug wire order, when you were replacing the plugs etc.
oldcuda View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldcuda Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2016 at 12:04pm
Pull dist cap and check for cracks or moisture sometime condensation gets inside during storage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote brettmac Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2016 at 12:21pm
Plugs are wet when pulled. Haven't confirmed all 8 are getting spark. Good idea. Have only looked at one on each side for spark. Pulled cap and everything seems in order. Is it time to replace cap, rotor and plug wires. Hate to keep throwing money at this without any guarantee that they are the issue, but again am getting frustrated. I have owned boat for three years and plug wires look good. But they are the ones she came with. IDK what else to try. Thanks again to all. Keep the ideas coming. Regards Brett
sberard5 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sberard5 Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2016 at 1:44pm
Sounds like some sort of ignition issue to me as well. Same exact symptoms as when firing order is out of sequence. Double check your firing order and pick up a cheap inline spark tester (5-10 bucks) that you can try on each individual cylinder. That way you can see if and when it's firing. Also, if you're replacing things, points and condenser doesn't hurt. I believe the point gap is .018". You'll get it going with the help of CCFan network, they've come through to help keep my 76 Ski Nautique going. Good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2016 at 2:00pm
plug wires are probably not the cause, don't go messing with them right now.
verify your firing order first. new plugs are gapped to .035" ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote brettmac Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2016 at 8:03pm
Ok team CCF, i verified the firing order and brought home a spark plug tester. All 8 cylinders are getting spark. Damn thing nearly started during plug test. It didn't however. And yes Hollywood the gaps are good. How bright are those tester lights supposed to be? It seemed it was brighter on some of the cylinders than others. Brett
Duane in Indy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2016 at 8:28pm
It was running when you parked it. That says the firing order and timing is OK. Unless you messed with that part.
Throw in some new plugs or rinse those off with brake clean. I prefer new cause it would not hurt to have new at start of season.
Hold choke open and hold throttle open also. Use a hot battery and crank it over. If it does not go in 10 seconds or so THEN give her a few good squirts of gas. You sound like you have a combo of fouled plugs from the oil and old gas and also maybe a weak battery.
Also always good idea to keep the fire extinguisher and or a blanket handy when doing all this.   It ran before and it will run again. Good Luck, Duane
Keep the Starting Fluid at home!!!!
        1978 Mustang (modified)
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2016 at 10:34pm
Check ballast resistor. It is bypassed during cranking, which would give you some limited fire.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2016 at 11:06pm
Assuming this is a PCM engine he has, the ballast resistor is not bypassed during cranking.
PCM never did it this way
Others like Indmar for example did.
If you look at a wiring diagram for a PCM engine, you won't find it.
Some people have done it on their own, thinking it makes for better starts.
KenO
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2016 at 11:54pm
Yeah- what KenO said.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: June-09-2016 at 12:12pm
Just to recap
Gas is coming from a fresh gas can. Boat was laid up with a full tank of premium non ethenol with stabil. Have cranked down the new battery twice without a start up. Just a lot of popping and farting.
Plugs are wet when pulled. Pulled cap and everything seems in order. Is it time to replace cap, rotor and plug wires.
Fresh plugs, fresh gas, weak spark.
Time for a distributor tune up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote brettmac Quote  Post ReplyReply Direct Link To This Post Posted: June-09-2016 at 6:44pm
That's what I was thinking Hollywood. Thanks to all who chimed in. You guys and gals rock. i will post update after cap and rotor replacement. Brett
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: June-09-2016 at 7:50pm
Originally posted by Hollywood Hollywood wrote:
Just to recap
I really don't see anywhere where you mention what's under the distributor cap.
Does it have points or is it an electronic conversion?
It seems like you want to change the cap and rotor but make no mention of anything else under there other than "everything seems in order" which isn't very descriptive. You don't exactly tell what the cap and rotor look like either.
Maybe Pete will come and tell you he gets 35 years out of a set of points or maybe it's 50
but it's with some attention being paid to their condition. Don't listen, get a new set if you're getting a new cap and rotor
I bet Hollywood's tuneup would/ should include points if that's what is hiding under. there and then you might as well do the condenser too while you're at it.
Could be a weak spark you're getting from some points that need attention
You also mention that you verified the firing order, but haven't said what it is and hopefully the plug wires are going in the right direction around the distributor cap too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-09-2016 at 8:56pm
Could be a weak spark you're getting from some points that need attention .
Ken,
I'm glad you brought this up. Yes, I too see no mention of what's in the distributor.
If points, what is their condition? Have they been filed to clean them up? A surface corrosion is common after a layup.
Ken,
Yes, I do get fantastic life out of a set of points but not the 50 years you mention!
Post Options Post Options   Thanks (0) Thanks(0)   Quote brettmac Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2016 at 7:37am
Replaced points, cond, cap & rotor, plugs and coil. Started once for a second and buddy inadvertently shut it down. Wouldn't start up again. What am i missing? Brett
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2016 at 8:22am
What makes you say "Seems like she's pushing ton of gas down the carb." ?
After you try to start it, is there gas dumping down either the primary or secondary bores of the carburetor
