Gasket Help needed, Intake Manifold |
Conor
Newbie Joined: May-09-2011 Location: Jax, FL Status: Offline Points: 6 |
Posted: July-01-2016 at 4:04pm |
I need some assistance locating the correct gasket. I have a 1989 Ski Nautique with the original PCM 351 engine. I am need of the gasket the goes between the intake manifold and the metal spacer.
I have tried the following two gaskets however neither one of these gaskets completely sealed the gap. Victor Reinz G30618 Felpro 60616 As far as I know the intake manifold is original. Any help would be appreciated. |
1989 Ski Nautique
gun-driver
What gap are you talking about?
You need a genuine PCM gasket or you have to make your own. Go to skidim.com and look at item 1127. If you have a PCM dealer they should have it the part number is on that above site.
Conor
The gaskets that I have tried do not exactly match the opening on the intake manifold and when the engine is running there is air leaking out. of an unsealed gap between the spacer and the intake manifold.
1989 Ski Nautique
