  New Posts New Posts RSS Feed - fluid type older velvet drive
fredo68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fredo68 Quote  Post ReplyReply Direct Link To This Post Topic: fluid type older velvet drive
    Posted: July-06-2006 at 3:51pm
everyone says type f for older velvet
drive, saying it takes a little over a
quart. looked everywhere for type f
did find type fa for older ford vehicles.
will this be allright or what?
fredo68
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2006 at 4:05pm
The older types used type A. My local NAPA carries it because people who have old farmall tractors use it.
Tim D
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2006 at 4:08pm
use any grade of dextron and you'll be fine. You don't need type F or type A fluid it's out of date technology and lubrication
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2006 at 4:11pm
Yeah, if you do a complete rebuild I would switch to dextron III.
Tim D
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2006 at 4:24pm
how much more BS are you going to sling today
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2006 at 4:35pm
Here's some for you.
Tim D
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2006 at 4:40pm
see your still a jack ass with out any good advice on how to fix things.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fredo68 Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2006 at 4:43pm
the drive was rebuilt about 2 years
ago by ft wayne transmission, so in
that case just go ahead and use dexron3
fredo68
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2006 at 4:49pm
dextron III or II what ever is available at the parts store. Just add a little of the second quart, you don't want to over fill it. And make sure you get the cap back on tight so that no water can contaiminate the fluid while underway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2006 at 4:50pm
and you're a dumb ass who still doesn't know your from you're. I hope you don't have to spell at your job.
Tim D
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2006 at 4:52pm
Clueless would fit better than Dowless maybe you could change it so everyone know's it up front.
Oh and you still haven't figured it out that it was a gramner error and not a spelling error dick head
Sorry for all the BS freddo
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2006 at 4:55pm
Wow, did you get help with that one?
Tim D
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2006 at 5:00pm
I just have a degree from a engineering school that is and was ranked in the top 5 of the world
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2006 at 5:17pm
So, I have 2 degrees. And your grammar/spelling/typing or whatever you want to call it, you still use/type the wrong word. Alright! I'm knocking on 500 posts.
Tim D
dans View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dans Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2006 at 7:35pm
Tim , thanks for your help with my rear seal issue. You were right on the money.The cc dealer ( Buxton Marine ) said the same thing today.I'm gonna fix it this winter , dealer said it was ok as well.On subject of lubes - I know strait 40 wt for my 82 is out dated oil , but cc dealer still says I should use it for this old motor. They stick to what the older tranny & motor manuals say at cc here in Dallas. Dealer here only upgrades oils on the newer boats . I thought that sounded crazy and called PCM, they backed it up.Not what I would do on my Acura,Jeep or Chevy , but they are the boat pros . Thanks Dan
1970 Mustang View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1970 Mustang Quote  Post ReplyReply Direct Link To This Post Posted: July-11-2006 at 12:17am
It makes sense, if you use older types of oils your motor will not last as long, thus you will buy more replacement parts or even better for CC; a new boat.
