Throttle Lever Lockout Ring not Working |
bpurnell
Groupie Joined: November-08-2016 Location: Alberta, Canada Status: Offline Points: 41 |
Posted: May-27-2017 at 3:28pm |
I have a 1991 Ski Nautique and the lockout ring on the throttle lever is not functional; that is the lever passes from forward to reverse without locking in the neutral position. The spring seems fine so I imagine there is a worn part somewhere inside. Anyone had any experience with this, and is it possible to fix?
Brian in Alberta, Canada |
SNobsessed
Very common issue.
I tried to fix it with a heavier spring, to no avail. I bought a replacement lever, that was at least 6 years ago. It was hard to find back then. Search for MV2 lever, maybe you will get lucky. It is just held on by a set screw underneath. |
Is the plastic lock pawl wearing out?
bpurnell
Thanks for the replies!
Not sure about the lock pawl. I will have to take it apart. If it is worn out is it possible to get a new one? |
SNobsessed
Search internet for MV2 lever.
