Quick Fuel float adjustments |
Post Reply | Page 12> |
Author | |||
1994nautique
Newbie Joined: March-21-2012 Location: Wyoming Status: Offline Points: 29 |
Posted: July-22-2017 at 1:46pm |
So I have finished doing the protec to carb swap and I have been trying to work the bugs out. I had the floats adjusted to spec with the boat on the trailer. We took it out and ran the boat and the carb started flooding out the engine with gas actually dripping straight into the intake with the throttle in neutral. So I figured I was getting to much fuel pressure so I adjusted the floats down so I could barely see the fuel in the sight glass. I added a fuel filter right before the fuel pump and took the boat out and it ran decent, it acted like it wasn't getting enough fuel, So I adjusted floats back up and ran good, still not the greatest at wide open throttle out of the hole. If I eased into the throttle it would take off better, no sputtering. I adjusted the secondary's so they kick in about 35 mph.
This morning I took it out and it was hesitating at about 30 mph. Did a couple hole shots and it seemed flat, didn't run anything like it did the last time I was out. I checked the float levels and the secondary bowl was good, the primary was to high again and the gas was running into the intake again with the throttle at idle. So I adjusted the float down and it started running good again. I went skiing and it ran good other than it seemed like it was flooding out when it started up... had to open up the throttle in neutral to get it to start. This is getting long winded and I'm sorry about that but I am running out of ideas on why I can't keep the floats adjusted properly. Any ideas are greatly appreciated! Thanks |
fanofccfan
Platinum Member Joined: December-13-2009 Location: North Bend NE Status: Offline Points: 1774 |
I am having the same issue of fuel dumping in at idle. I have adjusted the bowls several times. Hope I finally have it dialed in. I called quick fuel and the fella I had advising me knew less than I did and that ain't much!
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11050 |
If you have a piece or pieces of junk just upstream of the needle and seat randomly getting stuck in between them and bouncing around it'll drive you crazy trying to adjust the float level as the piece moves around..
I'd pull the bowls and look and make sure the fuel inlet and your fuel line from the pump don't have junk anywhere. |
phatsat67
Grand Poobah Joined: March-13-2006 Location: Indiana Status: Offline Points: 6150 |
Quick fuel is great with warranty if you end up needing a replacement.
Good luck. I've always had excellent luck with the float level adjustments. We had to warranty one because of accelerator pump underperformance but that's all. Currently messing with Mars' carb. I believe the back butterflies are open too far letting in too much fuel from the transition circuits causing a bad rich idle. |
1994nautique
That's about where I am, I've messed with carbs a bit but never really fine tuned one. I've never had issues with setting the floats.
I was kinda leaning towards taking the bowl off and checking, Thanks Guys! |
Duane in Indy
Zach, You must be speaking about when QFT owned QFT. Now that Holley has purchased them customer service is not what it was. Still a great product but normal Holley service dept. |
1978 Mustang (modified) |
phatsat67
Ahh. It was 2 years ago when I dealt with warranty. I returned it to summit.
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21169 |
Believe Holley purchased QF ~5 yrs ago.
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2957 |
1994 SNOB with a new QF M-600. One morning it started running super rich. Couldn't get the engine to idle. Ran fine at wide open throttle, but idle was 1,500 rpm or engine would die. I pulled the flame arresor off and saw fuel running into the mains. Back at the hacienda, I pulled the float bowl off and found that a small piece of brass had become lodged in between the needle and seat. This prevented the needle/seat assembly from stopping the fuel flow into the bowl -- hence the fuel running into the mains. So, I put in a new needle and seat assembly in the carb and it has performed flawlessly since.
The piece of brass looked like a small remnant left over from the machining process. I don't know where the brass came from, but I'm guessing from the fuel tank as I had recently replaced some of the brass fittings there. JQ |
Duane in Indy
Last year is what they told me |
Jonny Quest
+1 Same story I got from QF / Holley when I called to get recommendations for secondary jets. JQ |
JQ I checked with my dentist and he said to do a Google search and you'd probably find that in 2012 (that's what 5 years ago?) QF was bought by the holding company that bought Holley after some bankruptcy problems Holley had. Everything changed hands a couple of times and now there is Holley Performance Products Group that owns quite a few aftermarket companies and QF is one of them Holley history (a long and winding road) link Some QFT historyQFT So High Performance Industries who at the time owned Holley bought them in 2012 Then everybody changed hands again once or twice after that. That's probably part of the story So in the end I said to myself"who cares when it happened? or how many times it happened. Just one big incestuous aftermarket industry where everybody keeps getting bought and sold by investment groups Kinda like being married to your cousin or something and then divorced and remarried again I'm sure this isn't the whole accurate story because it's probably next to impossible to figure out but it sounds like everybody's right ...........sort of |
I hope 1994 Nautique is out playing with his carburetor instead of getting distracted by all this
1994nautique
I took the primary bowl off and found half dozen little tiny metal shards in the bowl. I didn't see anything on the needle and seat. I was hopingI would see something a bit bigger. I guess if it was bigger there would probably be gas dumping out of the overflow. I'm hopefully going to get out this evening and run it again fingers crossed.....
1994nautique
Well, took the Nautique out and so far so good no flooding. So the only thing at this time is when I hit it full throttle out of the hole it hesitates until about 2600 rpm then it takes off like it should. If I ease into the throttle it takes off no problem. I opened the gap on the plugs to .055 when I installed the dui, I was thinking I would close them to .050 and see how it runs. Any thoughts??
MourningWood
Gold Member Joined: June-13-2014 Location: NorCal Status: Offline Points: 915 |
One thing I've done with marine carbs is to extend the vent tubes a bit. (raise them).
Boats move up and down much more than most vehicles do. It helps. |
GottaSki
Grand Poobah Joined: April-21-2005 Location: NE CT Status: Online Points: 3357 |
I don't predict the gap to cure that. tell us.. Whats your initial timing at? What PV is in the carb? How did you set the idle mix? |
River Rat to Mole |
1994nautique
Never had time to change plugs this week.
The power valve is 6.5, the idle was set at one and a quarter out. When I set the idle screws I had a vacuum gauge hooked up to the carb vacuum port and I didn't have any reading at all. It is running terrible rich at idle. It loads up and starts fouling plugs until I run it at higher rpm. I was going to try 3/4 turn out on the idle for a while and try that..... Timing is at 10 deg. BTDC |
fanofccfan
My idle screws are turned out between 1/2 and 3/4 turn. They were more than 1-1/4 until I moved them in. That seemed to help on mine.
A picture of the vacuum port with the gauge hooked up might be helpful if you say you have no vacuum reading.
Have you verified the secondaries aren't leaking/dripping at idle. I see you took off the primary bowl but not the secondary. If you have junk in one you have a good chance of having junk in the other |
1994nautique
Turned the idle screws in this morning to 3/4 turn and she ran like a champ! I will try and post a picture with the vacuum gauge, This quick fuel carb has the two ports on the bottom underneath the primary bowl.
I'd imagine that you're at a fairly high elevation out there in Wyoming and the idle mixture adjustments make sense.
How high are you? elevation wise that is Good job, hope it keeps running good now |
1994nautique
Reeeeally high ha, at 6 am - the boats running good - and we're ripping up glassed out water
Elevation wise about 4200 ft. Thanks for the help! |
If you hook into the other port right next to the one you're probably hooked into, you should get a vacuum reading at idle.
One is full manifold vacuum and the other that you probably hooked into is the timed spark port that reads above throttle plate vacuum and at idle it'll read about zero. Hook into the manifold vacuum port and it'll give you the readings you're looking for. They look like they tap into the same place but they don't. |
1994nautique
Ok, I will try it, do I need to have anything tied into the port coming of the metering block?
Jonny Quest
Are you running stock jets? I'm in SLC area and I'm running 2 sizes smaller on jets for the altitude. I typically run between 4,400 and 6,200 feet elevation in Utah. FWIW, She runs like a scolded dog...
JQ |
That port off the metering block is also a "timed vacuum port" sensing above throttle plate vacuum so you don't need anything hooked to it.
I'd just cover it with a small cap. I'd probably also take JQ's advice on jets for your altitude. |
1994nautique
Sounds good, I will keep it plugged.
I will definitely be changing jets at some point, I've been fallowing JQ's posts with the protec swap. JQ did you change both the primary and secondary jets sizes? |
Jonny Quest
Yes, I changed jet sizes. I went with the rule-of-thumb of 1 jet size for each 2,000 feet of elevation. As such, I decreased jet sizes by 2 for primary and secondary metering blocks. One nice feature on the QF is that the secondary metering block has changeable jets. The 4160 does not.
Since the jets are fairly inexpensive, I bought jets for one, two and three sizes smaller. The carb also has changeable air bleeds, but I kept those at the stock setting. Most of my boating/skiing is at Utah Lake (4,400 feet elevation) so the 2X size reduction is spot-on. Out of the box, the accelerator pump was OK and the idle air mixture screw setting was also good. I have not had to adjust choke or vacuum secondaries. Where in WY are you? What is your elevation? JQ |
1994nautique
I am in the northeast corner, by Devils Tower, about 4200 feet.
Where did you buy your jets from? |
