  New Posts New Posts RSS Feed - 1999 Ski Nautique with Check Engine light
nic.meyer15 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nic.meyer15 Quote  Post ReplyReply Direct Link To This Post Topic: 1999 Ski Nautique with Check Engine light
    Posted: May-25-2019 at 7:56pm
I just bought a 1999 Ski Nautique with the GT-40 motor and my check engine light came on after about 15-20 minutes of driving. I did put in new gas beforehand, it did have about or a little less than 1/4 tank of gas and I filled it.
What would people recommend I do?
Nic Meyer
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2019 at 8:48pm
You could read the thread in the link for some info on what turns that light on as a good starting point
More information from you would be good too, like is your speed limited to 2500-2700 rpm or so when the light comes on?
gt40KS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gt40KS Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2019 at 3:29am
Have you visually checked your impeller? High cooling temps and low oil pressure are a couple common items that will set the alarm.
JCCI
1995 Ski Nautique GT40
