  New Posts New Posts RSS Feed - 79 Ski Tique - floor / stringer rot
edamario View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote edamario Quote  Post ReplyReply Direct Link To This Post Topic: 79 Ski Tique - floor / stringer rot
    Posted: May-17-2020 at 6:24pm
Hey Guys -
It's been a while, but writing for a bit of advice. I had a very soft (rotten) spot of flooring between the seats & engine and investigated as I was afraid of my ski pylon being compromised.   Boy was it... the flooring literally fell apart in my hands. I decided to cut out a significant amount of mushy (saturated) flooring which then revealed rotten stringers. This was not really a surprise, but now I have a ski boat that can't pull a skier.
Of course, it's Mid may and I want to use the boat this season. I don't have time or want to do a proper stringer replacement right now, so looking to do a one-season band-aid fix. My thinking is that I can marry a PT 2x4 to the bad stringers (or even composite?) , and patch the floor above.... Or I can notch out a bit more floor above the stringer and drill down in (if there's anything left). Does the stringer have a notch there, or is the floor what's rotten?   Either way, if I can get a solid enough grip, I'd drill the hole in for the pylon, and re-install. Any thoughts on how best to do this... and am I just being crazy?   For what it's worth, the only towing the boat would do is an 8year old on a tube so nothing aggressive by any stretch.
Pics attached... I ripped up the carpet and you can see the soaking wet wood...I peeled back the fiberglass and removed most of the wood by hand. Once I hit wood, out came the jigsaw, and in the second pic, you can see what I removed, as well as the compromised stringer. Note there's still rot further towards the battery, but I stopped at the parallel stringer.
Again, this is a temp fix. I get it... fix the stringers. Just cant now.
Sadly this little tique runs amazing, but I'm questioning if it's worth the work.
Thanks in advance - Eric
'79 Skitique - first boat
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: May-17-2020 at 7:41pm
I'd park it for the season & pick up an old beater outboard runabout to use this season.
I can't recommend stringer sistering as there is no way to know if it is going to be safe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote edamario Quote  Post ReplyReply Direct Link To This Post Posted: May-18-2020 at 11:31am
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: May-18-2020 at 11:56am
I did not have any rot, but had a stainless cradle pylon support made to support pylon
Holds it well. I’ll try and load pic
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: May-18-2020 at 12:00pm
http://www.correctcraftfan.com/forum/uploads/18449/68D9D7BC-CB95-4B76-BDD6-2B63BCC62BEA.jpeg
Above pic of cradle. It is in ccfan files
