  New Posts New Posts RSS Feed - carb bowl leaking - repair or replace
uncle-buck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote uncle-buck Quote  Post ReplyReply Direct Link To This Post Topic: carb bowl leaking - repair or replace
    Posted: September-04-2020 at 9:41pm
Just rebuilt an older Holley 4160 carb for a PCM Ford 351W engine.
Mounted it on the engine and ran it on the garden hose.
Appears to run great, *but* the secondary bowl is spraying fuel from the place marked in the attached photo.
Can it be repaired with solder or is it better to replace it?
If replace, who do you recommend buying from?
Holley, Summit Racing, eBay or another vendor?
Thanks
Post Options Post Options   Thanks (1) Thanks(1)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: September-04-2020 at 11:29pm
Some have repaired with JB Weld with good success.  Give it a try.
Status: Online
Post Options Post Options   Thanks (1) Thanks(1)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: September-05-2020 at 6:33am
Here's a link to a previous discussion on those plugs with a picture of what the plug actually looks like.
It has an internal O ring that's leaking.
A good cleanup job, and about any gas resistant epoxy covering the whole plug area and you should be leak free.
Epoxy or replace,............... your choice Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote uncle-buck Quote  Post ReplyReply Direct Link To This Post Posted: September-05-2020 at 8:42am
Does Holley sell that plug and o-ring?
I searched the site and did not find them.
Post Options Post Options   Thanks (1) Thanks(1)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: September-05-2020 at 2:04pm
JB Weld on my ‘85s for years no leaks.
Status: Online
Post Options Post Options   Thanks (1) Thanks(1)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: September-05-2020 at 2:53pm
I've never found them from Holley or any aftermarket type supplier.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: September-05-2020 at 5:09pm
They sell them they just come pre attached to a float bowl Wink  I have always wondered if you could press down on that plug and peen the ridge around it to tighten it up.....
