85 ski nautique 2001 with acceleration skip |
MitchsStitches ![]() Newbie ![]() Joined: July-06-2021 Location: wisconsin Status: Offline Points: 2 |
![]() ![]() ![]() ![]() ![]() Posted: July-13-2021 at 8:28am |
Hello forum hope all well,
![]() Just snagged an 85 nautique 2001 and she purrs like a kitten, once it hits 1500-2000 RPMs. right around 1000 there is a little skip and sometimes, if I don't floor it, the engine stalls. Has anyone experienced this problem and know any solution?
MI-nick ![]() Gold Member ![]() ![]() Joined: January-12-2009 Location: Ypsilanti, MI Status: Offline Points: 815 |
I had an intermittent "skip" with my '88. sometimes it would stall at idle. could never figure out the issue, then last year the electronic ignition module failed. new one fixed the skip. you may want to look into that if your '85 had been converted to EI.
As far as I can tell, I'm not quite sure...
samudj01 ![]() Gold Member ![]() ![]() Joined: March-10-2009 Location: NC Status: Offline Points: 982 |
Check the accelerator pump on your carb. Should see it spraying two streams of gas into the carb throat when throttle is pumped once. While boat is off, take off flame arrester and look down carb as someone pumps throttle.
