1985 Ski Nautique Key Switch |
Spotrep ![]() Newbie ![]() Joined: September-21-2021 Location: Rowlett, Tx Status: Offline Points: 39 |
![]() ![]() ![]() ![]() ![]() Posted: October-04-2021 at 5:02pm |
Hey Fellas! Im the recent owner of a 1985 Ski Nautique. The key switch that came with the boat was crusty and the key was actually seized. I removed the switch and got a direct replacement from Oreilly's. I thought it was odd that I found a perfect replacement from a local auto parts store. I got home and wired it back and relized that i couldnt kill power from battery to the boat. The switch is only 2 positions (run and start). Do i need to replace it with a 4 position switch (off-acc-run-start)? or a 3 position and rely on switch panel for the rest (off-run-start)? Also, once I get the correct switch how do I wire it? thanks all! Tyler |
TRBenj ![]() Grand Poobah ![]() ![]() Joined: June-29-2005 Location: NWCT Status: Offline Points: 21197 |
3-position is what was used originally. 4-position can be used (no need to connect anything to the accy).
KENO ![]() Grand Poobah ![]() Joined: June-06-2004 Location: United States Status: Offline Points: 11184 |
Click on the link below for a 3 position switch from SkiDim
You can wire it per the TRB diagram below Red to the Batt terminal on the switch Purple to the Ignition terminal on the switch Yellow/Red to the Start terminal on the switch ![]() You could also buy a 4 position and wire whatever you want to the accessory terminal or leave it unused
This forum is amazing. Thanks guys!
