  New Posts New Posts RSS Feed - ‘04 SN 206 Eng Temp Gauge
Arctic Blonde View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Arctic Blonde Quote  Post ReplyReply Direct Link To This Post Topic: ‘04 SN 206 Eng Temp Gauge
    Posted: July-12-2022 at 2:03pm
Hey y’all! Engine Temp gauge not working. Looking for any troubleshooting help!
Thanks and blessings!
Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: July-12-2022 at 5:44pm
Things to troubleshoot:
Bad temp sender.
Loose wire(s) at either or both ends.
Bad or broken wire(s)
Bad gauge.
Start with the wires as that has the highest probability of success — particularly if the gauge simply stopped working.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Arctic Blonde Quote  Post ReplyReply Direct Link To This Post Posted: July-12-2022 at 6:32pm
Thanks JQ! Guessing the sending unit is good because I’m able to read temp on the digital gauge (tach/speedo). I’ll check the harness plug next, then wiring to the analog gauge. Last will be the gauge itself.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: July-12-2022 at 8:35pm
Do you have Faria gauges in the boat?
Why would I ask that question? Wink
