  New Posts New Posts RSS Feed - 97 GT 40 - That black fuse in the battery box
nhhandyman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nhhandyman Quote  Post ReplyReply Direct Link To This Post Topic: 97 GT 40 - That black fuse in the battery box
    Posted: May-30-2024 at 6:59am
As I was running through all the GT40 threads about 'no-start' one of the threads mentioned the fuse in the battery box and that has caused problems in the past.
Well - that MAY have been my issue with no power to the fuel pumps when trying to start this year.  I did a lot of work to the boat over the winter - one of which was to replace the batter terminals and crimp ends - and I did remove/clean/check that black fuse - everything WAS checking out fine - I even followed it to the connection right next to the engine where it turns from RED to purple to confirm I had continuity from the battery to that point.
In any case, that thread which I can not find via search or browser history mentioned there was a modification that could be done to remove that fuse (or perhaps it was to modify it so it isn't an issue - I',m not sure).
So - I'm looking for a pointer to that thread.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: May-30-2024 at 7:57am
Might this be the one in the link below Wink
So have you solved your issue with pump power or are you still figuring things out
Post Options Post Options   Thanks (0) Thanks(0)   Quote nhhandyman Quote  Post ReplyReply Direct Link To This Post Posted: May-30-2024 at 8:23am
Yes - thank you.
And yes - I do believe the issue was the 50A fuse holder itself.  Fuse was not tripped (as noted in the link above that maybe 8G wire would have melted).   After tracing - taking it apart - cleaning it - tuned the switch and heard the prime cycle - which is what I was missing.
It seemed that they wanted to assure the module had power and ran that line - who the hell knows why. and why switch from RED to PURPLE?  That confused me while tracing - I had to use a scope camera to follow the wire.
I'll make that mod next year - but I'll do it BEFORE the boat is put to sleep for the winter - so I know it works and the kids are not loosing ski time (ya - I only drive the boat).k
Post Options Post Options   Thanks (1) Thanks(1)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: May-30-2024 at 8:34am
Glad it's fixed
You probably have a couple of extra relays now......but that's always a good thing Wink
