  New Posts New Posts RSS Feed - SOUTHWIND ENGINE?
SOUTHWIND ENGINE?
GARWOOD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GARWOOD Quote  Post ReplyReply Direct Link To This Post Topic: SOUTHWIND ENGINE?
    Posted: September-05-2004 at 11:25pm
HOW DO I TELL IF I HAVE THE ORIGINAL ENGINE IN MY 1975 18' "SOUTHWIND" ? WHERE CAN I GET ENGINE SPECS?
GARWOOD
reidp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote reidp Quote  Post ReplyReply Direct Link To This Post Posted: September-06-2004 at 11:08pm
First, I'd call Correct Craft in Orlando and give them the hull number. They should at least be able to tell you what size and make engine went in your boat. Maybe the serial number as well. Otherwise if you have the serial number tag still on the engine somewhere, go to the manufacturer if they're still in business if you can't decipher it to determine the year model. If your serial number year matches the boat year then I'd say it's original, however the short and or long block could have been changed at some time. It's not uncommon for an inboard engine's serial number to reveal that it's a year older than the hull. For almost any engine CC used during that period the manuals are still available. What engine do you have?
ReidP
1973 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote GARWOOD Quote  Post ReplyReply Direct Link To This Post Posted: September-09-2004 at 10:27pm
i'll check the numbers. i think its chevy V8 because of the distributor location. it has performer intake manifold on it now.
GARWOOD
