learning to foot |
Post Reply | Page 123 5> |
Author | |||||
87BFN owner
Grand Poobah Joined: August-25-2006 Location: Saline, MI Status: Offline Points: 2194 |
Posted: August-28-2007 at 7:50pm |
Pic of my brother learning to foot with instruction from Mike at GL.
Pics of him footing once we got home and have had a little practice.. I plan on getting some more pics this week end as the camera batteries went dead when I started to foot this was all she could get. I should have known better then to go out and not have changed the batteries after GL. |
Keith
Admin Group Owner / Operator of CorrectCraftFan.com Joined: October-20-2003 Location: Pepperell, MA Status: Offline Points: 1917 |
James - that's sweet! Good job guys. Next comes short-line I'm sure you have, but take a good look at that video we got from Mike. I've found it very helpful.
After GL I've been footing as much as I can with Brad (Barracuda), Tim (TRBenj) and Larry (75tique). With the help of those guys I'm now very comfortable at the short-line. Last night got up long-line, deep-start for the first time. It can beat you up but sure is a lot of fun. -Keith |
87BFN owner
Keith
We have moved to the short line off the bar. Just no pics as the camera was dead. Jake as had more good smooth water time so far and has progressed to deep up start off the bar off the short line like Ken did when Mike was with us at GL. We have not had time since then to get out. But we will be out this week end. Glad to hear your footing is progressing as well. |
Mark Mel
Gold Member Joined: September-16-2005 Location: United States Status: Offline Points: 583 |
I got up footing longline the other day - for 2 seconds. The wipe out rang my bell a little, lol. It was the first time I ever tried to foot, learning it oldschool, no boom.
I have no problem getting to the butt glide, I'm having problems cheeking outside the wake, any tips? Also, I only have slalom ropes, how much difference would a footing rope make? I think it will help with the bouncing that happens sometimes, no? What is the difference between a wakeboaring rope and a footing rope, they're both low-stretch, right? Also, what's the formula to figure out the right speed to plant? I'm 180 lbs. |
Barracuda
Moderator Group Joined: November-17-2003 Location: United States Status: Offline Points: 998 |
Mark- Handle position is key here- glue it to your hips. Pin your knucles to your suit and keep the handle there till you're ready to plant/ stand up. You can spread your elbows out wide and use them to brace yourself as you lean over for the cheek out. Don't sit up too straight- keep leaning back a bit. Another thing that helped me was to start leaning in the desired direction as soon as you start coming out of the water. That will keep your momentum heading up and over the wake. Good luck Remember to tuck your chin in when you feel you're about to fall. Didn't do that the other night and still feelin it
weight/10 +15 then add a couple more when on the long line. I would think 37 would be okay for you. I'm no expert here, just passing along some tips since I just went through this learning process. -Brad |
87BFN owner
Mark Mel
The no stretch rope is definitely the way to go. The wakeboard rope is typically on 75 feet a barefoot rope is usually 100 feet, the extra 25 feet helps alot. I think you can find the plant speed formula at I want to foot post. ON another note my brother and I progressed to the 100 long line deep ups on sunday. By the time the water got smooth enough for us rookies to give it a go and have a chance at getting up it was to dark to get a pic because of the distance from the boat. It took a few tries to learn how long to wait before trying to sit up and then get up on your feet but we got it. My brother made it outside the wake through a turn then back inside the wake on his own after the turn... Thanks again Keith and Alan for asking us to participate in the barefoot clinic at GL it has helped us greatly. |
Hollywood
Moderator Group Joined: February-04-2004 Location: Twin Lakes, WI Status: Offline Points: 13520 |
This is technique and will get easier with practice. Get atleast a 90' low-stretch rope and you can butt-glide and stand up all behind the boat.
HUGE. Get one immediately, too many reasons don't even know where to start.
Not really, you're bouncing on the stern rollers. Your sitting position technique will also make a difference here. Wearing an extra pair of wetsuit shorts underneath will help smooth it out and get a little more on top of the water.
Same stuff, "footing" ropes are usually 20' longer.
Eh, most of our speedos don't work very well anyways. I've always heard: Weight/10 + 20 for longline. Technique will come into play again here. A beginner will plow much more water than an experienced skier, thinking they need more speed to get on the water. Your foot positioning and how you support your weight will make a big difference. |
Mark Mel
Thanks for the tips, we're using a gps for speed and I think I was trying to stand at 37.
I will try to get a footing rope soon. Trying to do this on the cheap, I got two footing suits, a pair of lovely neon barefoot shorts and another shorty wetsuit for $33.50 on ebay. ;) Hoping to stand for more than 2 seconds by the end of the season. |
behindpropeller
When cheeking out make sure you are not laying flat once you are on top of the water. You want to sit up and bend your knees while resting your feet on the rope. When you are in the correct glide position (butt on water) you should be able to let go of the rope, and it will not pull out of your legs.
Contrary to othersI start footers out (after learning on the boom w/5ft lead) with a 45' rope which makes the initial cheek out a lot easier. This also puts you in a nice soft spot just outside of the wake. Tim |
quinner
Mark,
I have always used the weight x 10% + 20 formula for long line, in your case 38mph. If you really want to get outside the wake your driver can assist with this, while on your butt glide (around 20mph) have the driver swing you out just enough to cross the wake just as they are throttling up to speed, can be tricky to do or may take a little practice so they don't whip you too hard out and then right back in if you wait too long. Like Hollywood said get a longer line and stand up just off the white wash of your wake. Cheeking requires leaning on right cheek and pulling in slightly with your opposite hand to turn right or vice-verse to go left. Another tool to work towards your deeps is sitting on a kneeboard and standing up from there. Toughest part can be keeping the board under you at the start, sit towards the front and wrap your legs just above the ankle around the tip of the board, boat in gear helps keep everything in place, have driver accelerate slow/steady up to about 18, get stable on the board maybe move forward just a bit more and outside the wake, when ready signal to throttle up to speed, the more you plant your feet the more the board will rise almost standing you up. Another advantage of this technique is less water up the nose. Good luck |
behindpropeller
Kneeboard is OK but an old wakeboard is much easier to get up on too. If you are bouncing a lot you need to sit further fwd on the board. I would always rather teach on a kneeboard/wakeboard longline because a good driver/skier can spot most mistakes before you are up to speed. Tim |
jdkenyon
Senior Member Joined: March-16-2007 Location: Twin Falls, ID Status: Offline Points: 111 |
The speed isn't as critical if you have the correct technique. I normally run somewhere between 39 and 42 (wherever the wife can get it settled in at) and weigh about 190 with the barefoot suit on. Yesterday she didn't speed up as fast as normal but I planted anyway. I knew it was too slow but I made it with lots of spray. After the run she told me I was crazy for planting at 32. I think keeping your speed on the slow side will really help you from getting too sloppy. My dad learned to barefoot behind at a boat that could barely hit 35 with him behind it and he was in the 220-230 range at the time.
87BFN owner
The tape on your nose trick that Backfoot mentioned works great. We used it sunday, end result remove tape blow nose twice and no fish bowl effect. Thanks again Eddie.
Mark Mel
Oh, one other question, assuming I do make it up, how do you stop? Other than a spectacular fall that is.
Just let go of the rope? |
87BFN owner
I let go of the rope, then place hand on oposite shoulders, and then lean back. SEems to work pretty well, as once you let go of the rope you sink pretty fast. Leaning back should put you safely on your butt and keep you from face planting. Some of the other guys will have some better imput I am sure.
Keith
Bend your knees until your butt touches the water, then lay down on you back, lift your feet off the water and let go of the handle. You'll slide along on your back and gently glide to a stop.
backfoot100
No problem Jim, glad it worked out for you. |
Eddie |
Keith
While we're sharing ... here are the results from my first day of long-line. Did this while trying to cheek outside the wake. My feet got caught in the wake and flipped me forward, rope and handle nailed the inside of my knee on the way out. Did manage to get up that day however, after a short rest in the boat.
behindpropeller
I usually tell people to count to 5 once they are up for the first time and let go. Two reasons: 1. You get tired on your first run. 2. Its a lot easier on the skier to let go and find out what they are doing wrong rather than hold on, loose their form and faceplant. Tim |
Mark Mel
I'll try the count to five thing and lean back, assuming I can make it to five ;)
jbear
Wow does that look nasty Keith. I always worry about letting go of the handle and having it hit the top of my feet. Saw a guy do that once and the handle just opened up the top of his foot.
john |
"Loud pipes save lives"
quinner
JBear is right on, don't know if that was mentioned earlier in this thread but you really don't want to let go on your deep starts, learned that the hard way and it hit my foot and broke a couple bones. Take your time, no need to over accelerate, only learn on good water with the proper gear and it's also a good idea to run through you projected pass and scan for debris/dead fish/etc. in the water before proceeding.
jbear
Forgot about the dead fish quinner. Hit one as I passed our dock lookin at the dock to make sure everyone saw my grave jump instead of watching where I was goin'. Those fish bones can go pretty far into your foot. And the dr I went to didn't believe how I got 'em. They can make a real good infection too believe me.
john |
87BFN owner
I got a couple so so sets in this morning, storms started blowing in. I got some pics I hope to get posted tonight or tomorrow night. Footing is in the forecast for sat and sun. Pregression is coming along nicely.
Keith that looks like it really hurts, glad to hear you got up that day though. I agree the 100 of long line behind the boat is a new ball game compared to the boom off the side of the boat. |
Mark Mel
Well, I officially have no problem getting to the butt glide. I can ride all around the lake on my ass. So I'm not yet a footer I'm more of an asser. I can not for the life of me cheek out. I think/hope it's due to the 75' slalom rope that is putting me in a spot on the wake that is holding me in the center. I can feel it when I try to move out, feels like I'm stuck.
I'm getting an offical 100' rope today. I hope that puts me in a better spot on the wake. |
Boat speed could also be playing a part. How fast are you going when youre assing around? |
tullfooter
Grand Poobah Joined: March-02-2007 Location: White Lake, MI Status: Offline Points: 2225 |
I agree with the speed theory. Keep the speed down while trying to cheek out.
Yesterday, I had a friend of my son's learn to two ski on the boom and an hour later, he was footing on the boom. What a great teaching tool. Lefty |
Play hard, life's not a trial run.
'85 BFN '90 BFN White Lake, Michigan |
Mark Mel
LOL, "so what did you do at the lake today?" "I was just assing around" I would guess that I'm just coming up to speed. At what speed should I be cheeking out? By the way thanks for all of the great suggestions in this thread. |
You should be able to cheek pretty good ~25mph. |
behindpropeller
Shorten your rope to 22 off with the slalom line, you will get it no problem. Try it. |
