  New Posts New Posts RSS Feed - Mustang found
Mustang found
KevinPaul View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinPaul Quote  Post ReplyReply Direct Link To This Post Topic: Mustang found
    Posted: September-28-2004 at 4:28pm
I went to look at a Mustang today, the owner wasn't home, I never did meet him so I have no connection to him whatsoever. The boat was not what I was looking for, but I thought I would post this in case someone is looking for a Mustang project. It is an older model, unsure of the year, it has a throttle pedal, no molded scoop on the forward deck, just 2 small chrome scoops, gauges (mis matched) straight across the dash. Ford straight 6, terrible seats, painted hull & deck (not well done) factory engine cover, loose pylon, the hull under the prop was gouged and there were some metal plates sandwhiching the hull at the strut so I think it probably hit something and the yanked the strut allowing the prop to gouge the hull. The windshield is a modern one, but looks good on the boat. Floor shifter. It is on a trailer.
It was in a local paper, the boat is in Midland Michigan, is listed for $2100, and the phone number is 989 860-0075. This is just a synopsis from memory. It seemed like quite a project. The floor was plywood, I could see into the gaps here and there under the where the motor cover lays and it looked like the foam was removed. It had carpeted floor and inside walls.
Kevin
'69 Barracuda
