Drain plugs |
starbucksdad
Groupie Joined: September-13-2005 Location: United States Status: Offline Points: 80 |
Posted: April-29-2008 at 6:49pm |
Hey everyone thanks for all the help, as soon as it gets spring again I think I will back her in the river and see where the water comes out. Next year I will replace all plugs as soon as block is drained. Have a great Ski Nautique season...
starbucksdad
BuffaloBFN
Try a search for drain plug on this site. I think I remember a good pic with labels from TRB. Drain pics |
Carl, The idea of getting water in the engine and seeing where it comes out is a good one. Looking at a picture may not be that clear. The block drains as mentioned, are diagonally opposed. You haven't mentioned the plugs in the exhaust manifolds. You did find those correct?
shawnmc
Senior Member Joined: March-17-2007 Location: United States Status: Offline Points: 282 |
i have my 86 manual. Do you have a fax and i will send a copy to you tomorrow. I can try to have someone at work scan it in to a pdf and email you
SNobsessed
Well here is another idea - Pour water into the RWP hose (elevated above engine). Your drain hole will then very obvious.
starbucksdad
I found the one on the port sise toward rear of engine however I cannot find the other one.....Thanks,wish I had a picture from a manual or something..
starbucksdad
SNobsessed
Drain plugs go in each side of block. One is towards the front, the other toward the rear.
Look again. |
starbucksdad
I Have a 1986 Nautique with PCM. pulled block plugs last fall and now I have gone brain dead cannot find where they all go. One in water pump,found one on port side rear, and cannot find the other one........I feel really stupid....help please...Thanks
starbucksdad
