Replacing Exhaust Hoses |
Post Reply | Page 123 4> |
Author | ||
Sam B
Senior Member Joined: November-17-2007 Location: StevensPoint WI Status: Offline Points: 393 |
Posted: September-28-2008 at 12:56am |
Kevin,
My Email is samb.1@att.net I work at Vision Racing Tony George's team. |
kevin719
Senior Member Joined: June-18-2008 Location: United States Status: Offline Points: 231 |
Sam send me your email again please.Do you work for Ganassi? I have a good friend of mine that I think still works there.Dont spaek as much since we both got married
kevinindy
Sam B
Pete,
I am with Pete B on this if your gell coat is not cracked try to wet sand and buff. This seems to help uphold the value of your boat. Mine had some cracking so I had it painted. If I had it to do all over again I would have bought a boat with no cracking and sanded and buffed. But if painting is needed call Jason 317-850-5531. He is our composites expert at the raceteam. Before that he was the painter at Ganassi Racing. His work is a little spendy but you get what you pay for.If you would like to see his work come on over. Sam |
Pete, Is it that bad? Any gel cracking? You should be looking into re gel coating the hull. |
coltsphan
Senior Member Joined: August-14-2008 Location: United States Status: Offline Points: 112 |
Hey Sam. No more secrets here. I came clean. Not as bad as I thought it would be.
Who did your paint and how much was it? The second hull seems to have good stringers but needs paint. Thank. |
Sam B
Kevin,
I would love to have you swing over and check it out, just let me know when . I will be helping a friend move on Saterday and I will be out at Racoon lake on Sunday. So any time During the week is good for me. Do you still have my Email? Pete, Good deal! Now you have all the parts to finish your boat. How do you hide two from the wife? |
coltsphan
Hey Kevin. You and Sam should come by. I just picked up a second 67 Mustang yesterday in Atlanta. It has all of the original parts.
kevin719
Sam we need to hook-up sometime so I can check out your boat and maybe get some ideas for mine! I have the crusader engine as well and really like those stainless pipes! Kevin
kevinindy
Sam B
I bought 4 90 degree stainless 3" bends from Jegs. Tig welded them togeter then polished. Sounds great!
Bends $50.00 each x 4 Just another recipt I dont show the wife. |
74SkiNautique
Senior Member Joined: July-29-2008 Location: Lynchburg, VA Status: Offline Points: 228 |
The Kinked hoses were blocking A LOT of exhaust and water from escaping, now, i found my self doing 40 mph, when i thot i was doing 32! Gets there much faster!
74SkiNautique
kevin719
Sam how did you make those stainless pipes? They look great! Kevin
kevinindy
Sam B
I think he was trying to say Sam.
Luchog
??????????????????????? by the way, that red Crusader looks awesome!!! |
74SkiNautique
Looks nice sam. My new hoses really made a huge difference in performance. MUCH more acceleration.
74SkiNautique
Sam B
I made stainless exhaust hoses sounds realy good. Just another idea for you guys.
74SkiNautique
We are all finsihed with out exhaust replacement. The engine is MUCH louder than before because the manifold hose was about 80% blcoked due to a kink! The photos are backwards somehow, so the last picture is really the first picture. So You can click slideshow, then click reverse order! check 'em out!
Exhaust hose pics |
74SkiNautique
74SkiNautique
Yea, I think my Grandpas 89 SN has an idler gear or something that reverses the transmissions output directioin. |
74SkiNautique
coltsphan
Hey Kevin, my diary is up and running. I only have two pics. I will add some more soon.
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21166 |
That piece of advice is all well and good when youre dealing with a boat of this era (70's), but dont forget that 89+ Nautiques with the 1.23 trans use LH engines to spin RH props. |
88 Nautique
Senior Member Joined: September-20-2006 Location: United States Status: Offline Points: 221 |
Chris, Here's a good post from Randy in Ohio on posting pics: Posting Pictures Kurt |
74SkiNautique
I got it drom DIM. It is Premium 3" corrugated with wire. Designed for bends over 20 degrees. THAT STUFF WAS TOUGH! My dad and I Barely got them on the manifolds AT ALL! I took pictures of the finished job. LOOKS GREAT! |
74SkiNautique
kevin719
Which hose did you buy? My front hoses that connect to the manifolds both had pretty nasty kinks as well! I thought that the p.o. just did not slide the hose on far enough but he might have used the wrong hose for that first section that makes the bend.
kevinindy
74SkiNautique
I got all the hoses off today and completed reinstallation on the port side. Looks great. Better than factory, the factory hoses had two big kinks in them. The front hose was about 70% blocked. I will send pictures if you want. I just need your email. I cant figure out how to post a picture in my text!!!
74SkiNautique
74SkiNautique
No, I spent so much time reading all these non-related posts, I forgot to take my pipes off. I'll try again tomorrow. |
74SkiNautique
kevin719
74 yes thanks for your email! The boat dr. pretty much described what you built as to what came in my boat from the factory!Thanks again I really appreciate it!Kevin
kevinindy
74SkiNautique
On mine, the engine info plate says R in big letters. I assume this is the engine rotation. |
74SkiNautique
74SkiNautique
Kevin, did you get my email.
74SkiNautique
kevin719
http://s36.photobucket.com/albums/e23/kev00692/boat%20pipe/
kevinindy
kevin719
Sorry to get off topic! Here is pics of mi copper pipe.I cleaned it with my die grinder and a 3m scotch pad.I call it a gasket remover.It took about 10 minutes to get the entire pipe and another 5min sanding by hand to get the bulk of the swirls out.I finished with 2 coates of engine clear to hopefully keep it looking clean.There is before and after pics.
kevinindy
kevin719
kevinindy
