Water Logged Foam... What are my options? |
Post Reply | Page 12> |
Author | ||
Sam B
Senior Member Joined: November-17-2007 Location: StevensPoint WI Status: Offline Points: 393 |
Posted: October-06-2008 at 10:25pm |
Chris,
I bought them from Freelance Lettering in Indianapolis. Andy the owner is a SN nut. Yes they are Airguide. Sam |
Chris73SkiNauti
Newbie Joined: September-04-2008 Location: United States Status: Offline Points: 8 |
Thanks for the advice, Sam!
BTW, nice job on your boat - where did you get those speedo faces? Are they Airguide or something else? |
Chris Bain
1973 Ski Nautique - the Retro Rocket! |
Sam B
I took my wetfoam out and im not looking back. Foam under your gunnels is a good idea.
Chris73SkiNauti
The guy I bought the boat from did the platform - stripped it, stained it, coated with marine spar varnish. It was immaculate when I bought the boat 5 years ago. The edges are wearing and so it's time to refinish it again. That can be another part of this winter's fun!
As far as the foam under the floor goes - that's mainly for flotation, but doubles as floor support, right? If I rebuild the floor, can I put the foam up under the gunnels instead to get the flotation? I like the idea of allowing water to get out of places it shouldn't be... :-) |
Chris Bain
Thomas,
Your statement is what really happens in the real world! It's the reason I'm pro no foam and providing drains from all the stringer cavities to the center bilge when doing a re stringer job. You're correct that even with the best of care, water will eventually get in there. Chris (74), If your boat has never been re stringered, I'd say on a 74 you have water. Pulling it over a scale to check the weight against the original specs would be interesting. Chris (73), Great looking boat! What coating did you put on the swim platform and how long ago? Is it sticking to the teak? |
tleed
Senior Member Joined: August-24-2004 Location: United States Status: Offline Points: 267 |
Hah, hah, 74SkiNautique, that's a real laugher. I'm not making fun of you, but that's the way I've treated my boat the last 3 years. Mostly. Bilge coming into the dock, pull the plug out of the water, no water in the bottom by the time I get 25 miles home.
However... I haven't had inside storage and I've never had a cover over the boat. But I doubt that's the real problem. These boats are designed to keep water out of the chambers on the outboard side of the stringers. They have a layer of fiberglass under the floor that attaches to the side walls and top of the stringers. It's supposed to channel water that comes in and passes through the plywood floor to the bilge where it can be pumped out. However, over time, leaks develop and water makes its way into the outboard chambers below the floor. There, it is absorbed by the flotation foam, which, again over time, becomes porous and acts more like a sponge. Once the foam "sponge" becomes waterlogged, it holds the water forever. The chamber now works in reverse of the design. Since there was no good way for the water to get in, there's no good way for the water to get out. There aren't any drain holes through the stringers to channel water back into the bilge. Any holes in the stringers become avenues for rot to develop. I'm spelling this all out for a couple of reasons. One is to second the notion that it's impossible to be too careful about storing the boat and keeping water out. Another is to nuke the idea that keeping large amounts of water out will forever forestall rot, because the real problem is that once water gets in, it NEVER gets out. Of course, I'm sure frequently adding more water to the stored water can't be helpful. Comment anybody? |
Thomas
1974 Southwind 18 with 318 cubic inches of reverse rotation roller cam "Moparvation" |
74SkiNautique
Senior Member Joined: July-29-2008 Location: Lynchburg, VA Status: Offline Points: 228 |
My boat, even after a full day on the lake, there is not enough water in the bilge to pump out. We always pull the plug, so by the time we get home, no water is in the bilge. Keep it dry as possible.
74SkiNautique
eric lavine
just to add to the comments, i cut up a boat Friday and the last time it was tagged was 1995, i hit a spot on the transom and about a gallon of water poured out, the top was solid but once i got near the gimble it was wet, probably that way for years. keeping these and all boats dry as possible is key to the longevity of the boat, inside storage, pull the plug everytime out, leave off the cover on sunny days etc..
tleed
Uh, my "interior" leak turned out to be a disconnected exhaust hose. It leaked like that slowly 3 years before it finally let loose completely and I finally figured out what was causing it. With so much water at the end it stayed hot, which is how I finally figured out what was wrong.
Another symptom that finally fit was when I ran it on dry land, I noticed it took a lot longer for the driver's side exhaust to expel water, which is because it had to first fill up the interior underfloor chamber before it exited the tailpipe. Thomas |
Thomas
Chris73SkiNauti
Hi All-
Back from the lake with pics of my boat. I also noticed that water is starting to seep out of the foam area, which makes me thing the leak is coming from the outside instead of the inside (since it's below waterline while sitting there). If there is a chip in the gel coat under water, will that let water into the hull? It's possible the outer layers of fiberglass are exposed to the water in a couple small spots - I have to check it out again... Thanks. Chris |
Chris Bain
kevin719
Senior Member Joined: June-18-2008 Location: United States Status: Offline Points: 231 |
I worked in the body shop field years ago and I remember the poly resin to be much more runny and no thickening agent for it back then,I am not sure if they even have it now! I used the west thickening agent in all of my batches so far and it works really well! I put back together many f600 front ends back then I can second that the poly is not as adhesive!
kevinindy
horkn
I used coated deck screws and then I completely covered them in resin. No metal was left exposed unless it was SS or aluminum.
They were drops, so yes, I must have used polyester. Yes, I really need to load some pics up. Too bad this summer was shot with my home buying experience. I still have yet to get up to the cottage and get the timing on the boat right. I hope to get up there in 3 weeks. I kinda made it my vow to get it running as it should before I put it away so that it is 100% ready to roll next spring. This may be the first summer I have not waterskied in like 27 years if I don't get it rolling pretty soon. |
Tom the true test of coarse will be time. I'm sure you did a better job than the factory did so it may last longer than the original did. Did you use any screws putting in the new floor and stringers?
Did you have metering pumps used for rather large quantities of both the resin and hardener or was the hardener just drops of catalyst? The drops would have been polyester. To my knowledge, all boat manufacturers made the switch to epoxy resins starting more that 10 years ago. How about some pictures for us too? |
horkn
I can say that in the 6 or 7 years since I have done the job, that there is no sign of rot in any of the wood.
Poly or epoxy I have no clue as to what I really used. My guess is that it was poly. I do know that it worked quite well. Kevin, I will get a picture of that front seat to you. I will find my 35mm pics and scan it at work this week. |
BuffaloBFN
Yes, much more predictable.
Fire!!! LOL |
Alan, I find that using the metering pumps with the epoxy is more precise than guessing how many drops of catalyst needs to go into a batch of polyester. I've inadvertently made some real HOT mixes of poly!!!!
BuffaloBFN
I thought it was easier to mix accurately, and it can be used almost to the cure point. That's small batch logic I guess because I've seen a chopper gun in action, but I was fixing 1 boat. It's not near as hard on the nose and brain cells either! FWIW I wouldn't use it w/o the pumps. |
81nautique
Grand Poobah Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5779 |
Just curious guys, what is easier about the epoxy over poly resin? |
kevin719
I have been using the epoxy resin on all of my wood and it is very easy to work with!horkn that is what I wanted to do was put a newer style passenger seat and have been trying to find someone that has done it.Please if you find the pics send them to my email.kevin719@comcast.net And buffalobfn I will post some floor pics soon it is looking alot like yours now and I am much happier than when I just had the ply down! Thanks again.Kevin
kevinindy
BuffaloBFN
Expanding a bit on what Pete said, I found epoxy to be much easier to work with!
Thanks Pete! |
Kevin, Tom bringing up his use of polyester resin (mentioned in other posts) prompted me to urge you to use epoxy resin. I have mentioned it many times and just want to again. Polyester is hygroscopic and is one of the major factors in why the wood stringer systems fail. Epoxy isn't so it acts a moisture barrier. It's also the reason epoxy is used as a barrier coat for hull blistering repair which is caused by moisture intrusion into the polyester hull. When doing a stringer job, it's even important to get the epoxy on the bottom of the new wood where it touches the old polyester hull. Using polyester will not seal the wood and in fact will trap it accelerating the rot. |
horkn
kevin,
Here is a shot mostly of my navigator, Farley, but you can see a little of what I did. The rear seat was completely new, replicated in new wood, foam and tri color vinyl. The wood was all fiberglass resined to ensure waterproofness. The floor was a crazy job, all ply now, resined to keep it good for genererations to come. But the real engineering feat was getting rid of the bench style seat with no back on the passenger side for a spotter's seat. I hated that idea, so we tried to replicate the newer type nautique's bench, with my own spin on it. I used a captains seat from a Mariah that was new, so I saw no need to recover it, and the passenger corner wraparound bench was nearly the biggest single feat on the redesign of the bait. 2 normal sized people (usually a couple) can fit there. I know I have film pictures of the redo, before, during and after the restomod, but not on my digital camera right now. |
kevin719
horkn do you have any interior pics you can post or email me?? I would like to to see what you did with your seats.Thanks Kevin
kevinindy
horkn
It took me 250 man hours to replace the floor and re engineer the interior. I had soaked foam, but no rot on my stringers. I was lucky. I think I dodged a bullet by only having like 200 hours on the boat when I bought it in like 01. Otherwise, had my boat had more hours on it, I bet I would have needed to replace all the stringers. |
I found no more rot than I had already discovered- the only bad spots were at the tops of the stringers, under the gas tank, and below the front wooden floor section. The rest was perfect, so it was almost a shame having removed that glass- but I sleep well knowing that it went back together without a bit of rot. |
Chris73SkiNauti
I'll have it out on the lake this weekend - I'll snap some more pics of it and post them for you all :-)
Sounds like I'm in for a good time over the winter! Chris |
Chris Bain
Sam B
I would also like to see more pictures of your boat. samb.1@att.net
Sam B
Chris,
Nice boat!! My 73 had wet foam and bad stringers. The project was alot of work but well worth it. You will also notice that the wet foam is heavy. So by removing it the boats performance will increase. I had a 30 gal. trash container when I first filled it with wet smelly foam I could't lift it. Very Heavy. There was about 8 of these containers full total. Also when you remove your foam make sure you remove it all even the stuf way upfront. A 6" drywall trowel worked great for me. I could cut the foam using the trowel into sections then use the trowel to pop out the sections. Try to remove your stringers in one piece if posible to use as templates. |
75 stang
Senior Member Joined: August-11-2008 Location: northwest ohio Status: Offline Points: 475 |
I use acetone to melt the foam out of fiberglass molds. I can only guess that the recomendation was to remove the wet foam with the acetone and get rid of the water that way. Not a big help if the stringers are weak though. |
JoeinNY
Use a diamond wheel on that angle grinder, cuts like butter and doesnt wear down best 16 bucks I spent on the project...
