  New Posts New Posts RSS Feed - Airguide  Parts
Airguide Parts
Keith View Drop Down
Admin Group
Admin Group
Owner / Operator of CorrectCraftFan.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keith Quote  Post ReplyReply Direct Link To This Post Topic: Airguide Parts
    Posted: March-31-2005 at 7:02pm
Woody from SECC has Airguide stabilzer tubes.
You can reach him at 407-851-1965.
-Keith
Former:
97 Sport Nautique
1994 Ski Nautique
86 Silver Nautique
79 Mustang
tdkosta View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote tdkosta Quote  Post ReplyReply Direct Link To This Post Posted: March-31-2005 at 4:28pm
To calibrate the speedo, hook the pickup tube to an air source. At 17psi the speedo guage should be calibrated by turning the knob to 36mph
66polyhead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 66polyhead Quote  Post ReplyReply Direct Link To This Post Posted: March-31-2005 at 1:24am
FOUND IT!!
BOTTOM OF PAGE
nates78ski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nates78ski Quote  Post ReplyReply Direct Link To This Post Posted: March-30-2005 at 10:26am
I got some new original speedo kits from the 60" with the tubes. In fact one kit has thru hull bronze pitot"s. Email me for details
Nathan
My '78 Ski Nautique
<a href="http://photobucket.com/Nates78ski" rel="nofoll
Post Options Post Options   Thanks (0) Thanks(0)   Quote 66polyhead Quote  Post ReplyReply Direct Link To This Post Posted: March-29-2005 at 12:24am
Try a hand held G.P.S. they work great, other wise you have to measure off of the bank and use a stop watch, and hold a steady throttle. I had a airguide calibration chart that went off the first and second bouys on a slolom course. you go through at 35 mph, start the stopwatch at the first bouy, stop the watch at the second bouy, and the amount of seconds elapsed tells the actual speed with a variance. Sorry can't find the chart.
mackwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mackwrench Quote  Post ReplyReply Direct Link To This Post Posted: March-28-2005 at 7:08pm
While were on this subject.... Anybody know how to calibrate one? (speedo)
NO LONGER A MEMBER
Post Options Post Options   Thanks (0) Thanks(0)   Quote 66polyhead Quote  Post ReplyReply Direct Link To This Post Posted: March-27-2005 at 8:42pm
I have a few extra eq. tubes. There are two styles: 1. Old style with the pitot on a swing style block, and banjo bolt mounted on the bottom of the tube. 2. straight tube with a 1/8" barb fitting on both ends. the measurements on the latter are: 10" long 7/8" diameter, with a 1/8" barb 1/2" long. The worst thing that you can do is leave water in them when laying up for winter.
79nautique View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: March-27-2005 at 12:17pm
I thought you could buy replacement tubes at skidim when you bought the whole kit.
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: March-26-2005 at 12:11pm
Look at them as shock absorbers...just a large volume of air that can compress to eliminate needle fluctuations. Kind of like dumbing down the response time. I would think that any tube would work the same regardless of manufacturer.
68 Mustang View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 68 Mustang Quote  Post ReplyReply Direct Link To This Post Posted: March-26-2005 at 10:17am
Just got my boat out of winter storage. I pulled out my stabilzer tube and looked it over. It looks like the tube is just a piece of 3/4 inch pipe with small connectors on each end. The thing is hollow inside.I guess it is just an air gap between the pitot and the speedo. The one I pulled out is made of brass but I will make mine out of copper pipe. I hope this will work. Any comments would be great.
68 Mustang
nautique frk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nautique frk Quote  Post ReplyReply Direct Link To This Post Posted: March-12-2005 at 3:09pm
Looks like someone should re make all of the airguide stuff from the speedos , stabilizer tubes to the pick ups that mount on the tansom
JWA Bought out Airguide in 1997 then ran it into the ground . These are the best Speedos you could get
Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote 68 Mustang Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2005 at 10:07pm
Being Airguide is no longer, does anybody know if other brand stabilzer tubes work with the airguides? And if so where could they be located. I called skidim today about this and they said good question. Not what I wanted to here.
68 Mustang
