  New Posts New Posts RSS Feed - And so it begins...
And so it begins...
 Post Reply Post Reply Page   123 5>
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Topic: And so it begins...
    Posted: August-04-2010 at 12:17pm
sorry haven't seen a PM Paul,
but here's my .02, change the cam, little late to balance the rotating assembly but would be nice if it was, the pushrod length need's refined or your just waring them out that much faster, the heads need to be ported to the intake and the exhaust as well, care must be taken and judgment made as to how much to remove on the exhaust manifold so the mounting isn't weakend, the stock intake needs thrown in the trash and replaced, if a point dist conversion would be nice but not really a weak point by any means just frequent adjustments yearly or so depending on use.
My thoughts and regards towards Eric where created long ago after a phone call I made to him, and the years of ranting and raving from him on here as only added to that empression and that is my own personal feelings, to me he needs to stick with inboard trannies and that alone.
Keeganino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keeganino Quote  Post ReplyReply Direct Link To This Post Posted: August-04-2010 at 12:02am
Paul sorry about your boat troubles and the thread drama. Eric I don't think you have lost any respect here. Forget about it.
1973 Skier
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: August-03-2010 at 8:28pm
All right guys enough is enough.
I'll get this motor running the way it should one way or another. If I have to check rod length's or get another cam, it will get done.
Its a "build" that has to be tweaked to insure that all parts/systems have been adjusted and maximized to their full potential and working together.
Eric,
as I said I have no problem with the work you did for me.
Chris,
parts are parts the game is making them work together to maximize their potential. That's what makes this kind of stuff and racing fun and interesting. Who can put different parts together and make them perform better than the other guy. That's racing.
Now as for the allegations that I made up those e-mails or whatever you're insinuating, DON"T EVEN GO THERE, I saved every e-mail including the pictures of everything that was in the deal just so I could refer to them for the specs and for future information.
Don't you dare attempt to attack my integrity with slanderous remarks.
I said earlier if you want to help fine, help, don't attack everyone else that is trying to help me.
I sent you a PM to call me so we could talk about the best way to get the most out of this build...You never responded...If you want to help call me, but if you are just going sit back and make inaccurate accusations about everyone that is helping... then just shut the fu@k up and move on.
Waterdog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: August-03-2010 at 4:33pm
I spelled the way you spell, so I'd be sure you would get the point.
- waterdog -
78 Ski Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: August-03-2010 at 4:26pm
Originally posted by Waterdog Waterdog wrote:
   79 IS being slanderous and needs to stop all this childish stuff.
It's very clear your understanding what this word means and what truely constitutes the meaning is out of reach for you to comprehend and apply the word correctly, hopefully I spelled everything correct for you so you understand your error.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: August-03-2010 at 12:46pm
regardless, I suggested a cam spec much different than what was used, I told them that the heads need ported, I supplied an intake and exhaust manifolds and rocker covers along with the heads and rockers and a push rod guage and all the AN fittings to plumb the manifolds.
the cam information wasn't followed, the suggested machine work wasn't followed, the supplied intake wasn't used. I found it very odd that after several hunder hours of use and after honing the cylinder bores are within factory tolerance. So if that is all my fault so be it, I lost money on the deal to start with and even lowered my asking price from what I had all ready told other members inquiring about the parts.
SO IT's MY fault don't think so, they did their own dance with the engine and took none of the offered suggestions, obviuosly they had a better plan than I did sorry it didn't live up to what it could have if they would have listened. They had both heads in their possesion and could have compared combustion cambers, valve sizes, spring rates and runners, flow, anything you would want to know, did they? I can't answer that, but doubt they did.
I find it odd how someone specializes in inboard tranmissions only is always working on motors and never any other type of marine tranmission, maybe that's why he's not a BBB member or the body shop is doing the work. If it's my fault I'll shoulder that no problem and can deal with the mouth, because I know the facts and can sleep with them and rest very peacefully at night knowing the real reasons why.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: August-03-2010 at 12:20pm
Originally posted by gun-driver gun-driver wrote:
Originally posted by 79nautique 79nautique wrote:
   I never suggested any cam or stated any speed, only stated the valve specs, spring lift rating and that they need ported
Aug 2008 06:38:16 -0700> From: rcbroshar@yahoo.com>
> Subject: RE: 351W parts> To: pheinbach@hotmail.com>
> > Well they are pretty much bolt on pieces and the
> compression will go you a point or so as the combustion
> chambers are pretty small about 68-69cc's you are
> looking at an easy 50-60hp with a stock cam 75-100hp
> depending on the cam you choose, I can look up my old
> spec's for the cam I used and that will but you in the
> 310-320hp range.
•     RE: 351W parts‏
To Paul
Sent:     Thu 8/07/08 12:36 PM
To:      Paul Heinbach (pheinbach@hotmail.com)
this is in the ball park for what you would need, maybe a little more duration and a little more lift wouldn't hurt but don't change the separation: this is a comp cams spec, Now a lot of the guys lately have gone to cam research or cam resources I would have to ask Tim for the right name.
Cam Blank: 35-000-5RR
Grind # FW 5442/5444 H112 +2
Duration: 218/226 @ .050" (I/E)
Lift: .308"/.320" (I/E) (0.493"/0.512" w/ 1.6 rocker)
Lobe Separation: 112
"looking at an easy 50-60hp with a stock cam 75-100hp depending on the cam you choose"
Eric has a tough time reading I guess,
""this is in the ball park for what you would need, maybe a little more duration and a little more lift wouldn't hurt but don't change the separation: this is a comp cams spec, Now a lot of the guys lately have gone to cam research or cam resources I would have to ask Tim for the right name.""
that is my reply to Paul asking ME about a cam Paul or someone else spec'd and I state it's close but not quite and offer general directions on what to do and offer no specific numbers. You can go to Comps website and put in the nuber and get the specs as I did at the time, again I never gave specific cam specifications, I was leaving that up to his engine builder and at the time I didn't know who that was and if I would have know that I would have tried and presuade him to go another route.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: August-03-2010 at 12:12pm
Originally posted by eric lavine eric lavine wrote:
and yes that e-mail is verbatum from 79's mouth
sorry don't thing so
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: August-03-2010 at 12:11pm
> 310-320hp range.
•     RE: 351W parts‏
To Paul
interesting reading concidering I never had the cam blank number or grind number, I only recieved verbal spec info from Jasper and that Comp Cams was the supplier, you can even review the thread with me and one of the Iowa boys from back in the day white21 or something like that, it's been quite some time, that had basicly the same cam I had in mine, he discovered CompCams ground his wrong and talks about it in the thread and we both listed the specs for the cam I had in my motor and what He had in his. But regardless those specs are far from what was used in your motor so obviously the information passed along wasn't used or the suggestions that they needed ported as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: August-03-2010 at 10:32am
Hey Eric,
I can't blame you AT ALL for defending yourself.I've talked to you on the phone a bunch of times and I talked to Paul(Gun driver) for almost an hour the other nite. He's cool with ALL your work. 79 IS being slanderous and needs to stop all this childish stuff.
The best leaders get the job done without assigning personal blame
Some leaders I'd follow off the fantail, others I'd push off the fantail and Chris needs a nudge.
- waterdog -
78 Ski Tique
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: August-03-2010 at 10:18am
Need I say more.
you got me so fckin pissed off again, your messing with my livelyhood and never in the last 2 years since your back poking at the beehive have i breathed one bad word about you. but when you mess with me and my family I have a fckin problem with it. I dont care how big you are because you WILL fall that much harder...you can print this out because it is a threat. im thru with you
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: August-03-2010 at 10:07am
and to think I had a BRAND new set of good gt-40p's sitting there at the time that i ended up selling for 200 bucks, Im, not the thief here. im not going to tell the price what he paid for those boat ancors because its none of my business.
the block was honed and re-bore gauged, as were cam bearings installed...and no it wasnt per your big fckin mouth "pretty much bolt on"
you gave him a bonus reach around.
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: August-03-2010 at 9:40am
and im the azzhole???
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: August-03-2010 at 9:38am
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: August-03-2010 at 9:37am
lets re-iterate
pretty much bolt on
stock cam
75 to 100 hp...
your a used car fckin salesman
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: August-03-2010 at 9:34am
your ass cant talk your way out of this one
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: August-03-2010 at 9:32am
THIS IS THE SHT I HATE ABOUT THIS SITE, you know 79 you drug me in the mud once before and it cost me 3 fckin k, and i never said a word about it, and it again was somebody elses stupidity
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: August-03-2010 at 9:29am
does that say PRETTY MUCH BOLT ON, always trying to cover his ass..
DH!!!! yes i honed the cylinders and installed cam bearings. Ive done more engines in my sleep than you've ever thought of doing....stick to your desk top dyno and get real already
dont try to make me look like the azzhole.
what you were saying is slap on these heads to any tired old engine and you'll get boocoo HP..dont worry about the bottem.....well I did
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: August-03-2010 at 1:30am
> 310-320hp range.
•     RE: 351W parts‏
To Paul
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: August-02-2010 at 5:23pm
I know when Dad slapped a set of GT40's on his '92, he picked up a decent amount of RPM and speed- that was reusing the stock cam and intake. Maybe these (presumably lightly worked) DO0E heads just arent all theyre cracked up to be.
Maybe it is a tuning issue
your not going to be able to use that extra compression when it's blowing past the rings due to not touching the cylinder walls and adding new rings only and that will never seat properly and seal like they should if the block was machined and the bores honed to allow for the rings to seat and mate with the cylinder walls.
I would be keeping an eye on the oil, and keep a spare quart on the boat since it will be using oil and flushing the cylinder walls with fuel since the rings will never completely seat.
And yes it's very much a rebuild issue and not the way to go when dealing with custom parts in the hands of someone that doesn't know the proper methods to adjust and install the parts or how to match them with the rest of the engine components to get the maximum from them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: August-02-2010 at 5:17pm
with a stock cam and a stock intake it's really not going to do much might add some low end punch from the smaller chambers compared to what was on it before, but with out porting and a better cam and intake your not going to get much from the bigger valves, smaller combustion chambers and cleaned-up exhaust passage. If the time would have been taken to balance the rotating assemble and prep the block correctly then it might be a different story, but all that has been done is the engine torn down, main and connecting rod bearings replaced, the rings replaced and parts slapped on, so to ask or expect much more than stock your not going to get it or an engine that is going to last very long since your going to have excess carbon from the rings not seating correctly creating a loss of compression, throw in the fact the push rods are to short so the end result is an even weaker cam prophile than what is on the cam card, a stock intake to boot, so if all you where looking for was low end grunt then that was accomplished it sounds, but a lot more could have been done for a little more cash and time to do it right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: August-02-2010 at 5:06pm
Chris has implied that the heads in question have the small chambers (~58cc?), which would put the CR on the north side of 9. Your 302 had P heads, Joe?
Either way, I would think that a slightly better set of heads combined with a slightly better cam would still net more than a 1mph increase, especially when being installed on top of a new (read: lighter) structure. Maybe it is a tuning issue.
JoeinNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: August-02-2010 at 4:54pm
From all the talk Ive heard about DO0E heads, adding a decent intake and the right cam should have him in the 320hp range, shouldnt it Joe?
That would depend on ton on the actual compression, but with just valve work on those heads I highly doubt it. I did see in the 47.x range with that 302, but with better out of the box heads also with upgraded valves, also with rollers, new bottom end, 9.5:1 compression intake, cam, everything ported, better ignition etc.. even so if the two engines were the same horsepower it don't matter a darn unless they are both making it at the same rpm and that is the one that prop is selected for... a hot 302w making 280 at 4800, or a hot 351w making 300 at 4400 but down to 270 at 4800... the 302 is gonna run faster on a 2001 hull with a 540 acme even though the 351 has more HP.
I still assume the thing can be tuned a bit...
1983 Ski Nautique 2001
1967 Mustang 302 "Decoy"
Holeshot Video
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: August-02-2010 at 3:16pm
the other part and it's hard to tell in the pictures, put it looks like a stock intake is being used as well. And if the heads are not ported and using a stock intake and a stock cam, your not going to get much improvement, and then add all the other short cuts that where taken, it sure sounds like a brunstucky price and effort, take the money and run and who cares I got paid and did only what was asked and nothing more. I just concider the source and wonder why, expected it to a degree once I found out who the engine guy was. I never suggested any cam or stated any speed, only stated the valve specs, spring lift rating and that they need ported and provided the gauge to figure out the correct pushrod that was eyeballed and isn't correct, don't see how in the hell you can visually see where the middle of the cam lobe is so you can visually see the center of the valve stem, so I suppect that when the valve is closed it's centered and in actuallity it shouldn't be since it should be off center slightly at that point. SO it must be the parts since the mechanic picked the right cam, went the cheap route on the bottom end, cheaped on the the cylinder walls, and a bunch of other stuff, It just reminds me of the piss poor stringer job so now we have another to add to the many stories why it's the customers fault, seems to be a common practice of passing the buck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: August-02-2010 at 2:50pm
Originally posted by JoeinNY JoeinNY wrote:
I also don't think there is a cam in the world that would get that boat to a legit 50 with those parts.. just too slow of a hull I think you would need a legit 325 hp and a great and well matched prop to even think about 50.
From all the talk Ive heard about DO0E heads, adding a decent intake and the right cam should have him in the 320hp range, shouldnt it Joe? That would make them consistent with GT40p's. I do agree that such a power level (80hp over stock) should have a 2001 flirting with 50mph, assuming youre starting with one of the 45mph (stock) hulls, of which I have seen several.
Not having a good "before" picture makes this one a little tougher, but I would have hoped for a little better than 46mph out of that combo. Wouldnt your (~275hp?) 302 pull your '83 to 46-47? Then again, if he is starting with a "slow" hull, maybe thats not too bad. Who knows.
I do agree that Cam Research tends to err on the conservative side with these boats- though I have no problems with the cam they sold me. I am a bit doubtful that they would be so conservative as to suggest a .450/.450 cam for this build unless there was some sort of breakdown in communication though... like I said, that is basically a stock 351w cam, and the same specs were recommended to me on a 302 designed to spin 5000. Somebody missed something.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: August-02-2010 at 2:31pm
In terms of cams, I will say that I am not overly impressed with the Cam Research stuff I have seen, at least for pure high end performance. Not that the cams aren't great and that it isn't a great and necessary source for Reverse rotation stuff, but IMHO they error on the very conservative side when they hear ski boat and as a result the cams fall flat pretty quick on the high end. A lot of that is also limited by the manifolds we are choosing here, and yes it is a ski boat and first and foremost it needs a stout hole shot... but my various builds so far have never resulted in an engine that had a great top end but no holeshot. However I have built a couple that had pretty good holeshot and fell flat on thier face, and those were the ones where I was worried IMHO too much about the low end torque. The engines that have been/are great high end runners are also much more than stock out of the hole and they have much more agressive cams than I or others I have talked to had recommended by CR.
Again this all only applies to those of you with the particular sickness that drives a man to make his ski boat into a race boat in his own mind...
Holeshot Video
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: August-02-2010 at 1:33pm
you picked the wrong cam end of story, it's basicly a stock cam, and then you half assed the rebuild, and you expect the rings to seal properly without the cylinders being honed sorry they will always have blow-by to a degree and only get worse over time. Suppose you didn't bother with changing the cam bearings either. Then you want to say it's in the interest of good starts and drivability, please. If the engine is tunned right all you have to do is hit the key and it starts even with a pretty health cam and compression or sitting all winter, been there done that know how to do it right the first time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: August-01-2010 at 11:36am
lol, if your happy I'm happy.
imagine buying 6 larger turbos to get 1 mile an hour..that's the point your at
really though send your to kid to college and go run your boat, now if you want to break out your communion money you have tucked away........
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2010 at 9:51pm
Hey Eric whata ya think....a supercharger???
I don't nthink I used up all my daughters college money yet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2010 at 10:43am
I think Paul mentioned that i went above and beyond, fck if he said throw on a Vortech supercharger, here's the money...I wouldve. but going back he did come to me and said i got these great heads this and that i can you put them on and i said yes....but again it was my suggestion that since it was out i could pull the bottem down since we need to handle all that HP those heads will put out, I'll do the carb and give you a good qaulity turn key engine that all you will have to do is drop it in.
I ran my 400.00 bore gauge thru it and they were on the money, I couldnt use my eye cause i aint that good yet. re-bearing it, re-ringed oil pump and timing set.
now that would pretty senseless to slap on these fire breathing heads if the bottem was weak? I would hope you agree.
we both talked to scott and let him know exactly what parts we had and down to every detail. we didnt shoot from the hip, i gave him the head specs and so did paul and thats the cam we ended with. and my follow up call was going to the .500 lift may give you 2 miles per hour but the holeshot will suffer "with those heads"
Now,
sometimes you really fckin baffle me.
its a good strong engine, the rings need to seat and a few other things need to be dialed in, he did a couple runs on the weekend
and there are many suggestions from these guys and you are the reaper and in a way it seems like your trying to cover your ass because maybe those heads arent what they are cracked up to be
