  New Posts New Posts RSS Feed - Foot’s  New Tool Descriptions
jbear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbear Quote  Post ReplyReply Direct Link To This Post Topic: Foot’s New Tool Descriptions
    Posted: May-19-2009 at 12:30am
foot; laughing so hard I got tears...
'course I don't know what the real use for most of those tools is anyhow...
Don't forget the Masters pics...make sure Kim is in some of them.
john
"Loud pipes save lives"
boat dr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boat dr Quote  Post ReplyReply Direct Link To This Post Posted: May-16-2009 at 4:20pm
Tim, that is toooo true
See you and yours Sat. am at Calloway/Masters
nautiless View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nautiless Quote  Post ReplyReply Direct Link To This Post Posted: May-16-2009 at 5:18am
Excellent! I'd like to add if i may:
BELT SANDER: .....has a voracious appetite and eats it's own tail.
1982 SN 2001 RIP (Resto in Progress)
Don's Diary
critter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote critter Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2009 at 11:29pm
I have noticed that I am running out of Dammit Tools. I may want to go pick some of the used ones up for reuse.
1980 Ski Nautique
1966 Barracuda
Hooty222 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hooty222 Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2009 at 9:24pm
REALLY GREAT, Needed that....
1986 Ski nautique 351
1988 Barefoot nautique 454
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2009 at 4:23pm
I like 'band saw' and '2 ton engine hoist'!
1988 BFN-sold
azeus17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote azeus17 Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2009 at 4:10pm
Wouldn't be as funny if it weren't true!
Boats:
Current: 02 SANTE
Sold: 89 Sport Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2009 at 3:52pm
As there are alot of us who work with tools on a daily basis be it work or our hobbies I feel that the following definitions apply to ALL of us. ENJOY!
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal
bar stock out of your hands so that it smacks you in the chest and flings
your beer across the room, denting the freshly-painted part which you had
carefully set in the corner where nothing could get to it.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the
workbench with the speed of light. Also removes fingerprints and hard-earned
calluses from fingers in about the time it takes you to say, ''What
the...??''
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes
until you die of old age.
SKILL SAW: A portable cutting tool used to make studs too short.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of
blood-blisters.
BELT SANDER: An electric sanding tool commonly used to convert minor
touch-up jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija board
principle. It transforms human energy into a crooked, unpredictable motion,
and the more you attempt to influence its course, the more dismal your
future becomes.
VISE-GRIPS: Generally used after pliers to completely round off bolt heads.
If nothing else is available, they can also be used to transfer intense
welding heat to the palm of your hand.
WELDING GLOVES: Heavy duty leather gloves used to prolong the conduction of
intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable
objects in your shop on fire. Also handy for igniting the grease inside the
wheel hub you want the bearing race out of.
TABLE SAW: A large stationary power tool commonly used to launch wood
projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK: Used for lowering a boat trailer to the ground after
you have installed your new brake shoes,or hubs trapping the jack handle firmly
under the fender or frame.
EIGHT-FOOT LONG YELLOW PINE 2X4: Used for levering a boat trailer upward off
of a trapped hydraulic jack handle.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known
drill bit that snaps neatly off in bolt holes thereby ending any possible
future use.
BAND SAW: A large stationary power saw primarily used by most shops to cut
good aluminum sheet into smaller pieces that more easily fit into the trash
can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of
everything you forgot to disconnect.
CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER: A very large pry bar that inexplicably
has an accurately machined screwdriver tip on the end opposite the handle.
AVIATION METAL SNIPS: See hacksaw.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids and
for opening old-style paper-and-tin oil cans and splashing oil on your
shirt; but can also be used, as the name implies, to strip out Phillips
screw heads.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to
convert common slotted screws into non-removable screws.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket
you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used
as a kind of divining rod to locate the most expensive parts adjacent the
object we are trying to hit.
MECHANIC''S KNIFE: Used to open and slice through the contents of cardboard
cartons delivered to your front door; works particularly well on contents
such as seats, vinyl records, liquids in plastic bottles, collector
magazines, refund checks, and rubber or plastic parts. Especially useful for
slicing work clothes, but only while wearing them.
DAMMIT TOOL: Any handy tool that you grab and throw across the garage while
yelling ''DAMMIT'' at the top of your lungs. It is also, most often, the
next tool that you will need.
