  New Posts New Posts RSS Feed - Missing Exhaust Part!
Wheeler Dealer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wheeler Dealer Quote  Post ReplyReply Direct Link To This Post Topic: Missing Exhaust Part!
    Posted: July-01-2009 at 1:55pm
After all the fear of not knowing what and or how to solve my problem, my son and I decided to dive in last night and remove the old piece and have ordered and new from CC. Not as hard as expected, actual was a lot easier that I had thought. Thanks for all your help. Will be posting pics soon.
John
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: June-22-2009 at 11:56pm
John - The exhaust outlets I showed is all one pc. If you decide to change it, I suggest 1st cleaning you stern bilge area very well, because you will be face down in it reaching for the rear exhaust hose clamp. After that fun, then use putty knives, one on each side, to separate the coupler from the hull. Once you have a gap going, tap plastic tapered window shims under it to get it free.
So your idea of gluing a section inside sounds like alot less work!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-22-2009 at 3:44pm
Originally posted by Wheeler Dealer Wheeler Dealer wrote:
What do you think about putting in a piece of exhaust and connecting the flapper to it? Will this cause any restrictions? I really do not want to take it all apart for something that might be an easy fix.
Thoughts?
You're thinking about just finding the "tail piece" - just the round that came off the flanged assembly that's still on the transom? That sure would work if you can find it. It wouldn't restrict the flow anymore than original. I'd epoxy it to the existing. I mentioned the 5200 to use if your were going to replace the complete through hull exhaust in the transom.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wheeler Dealer Quote  Post ReplyReply Direct Link To This Post Posted: June-22-2009 at 2:36pm
Pete, thanks for your input. What do you think about putting in a piece of exhaust and connecting the flapper to it? Will this cause any restrictions? I really do not want to take it all apart for something that might be an easy fix.
Thoughts?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-22-2009 at 10:17am
The hose clamps inside are easy to get to. The question is how hard will it be to get the part out???
John
Getting the old one out won't be a problem since you're not going to be reusing it. Hammer, chisel, saw, grinder, etc. Install the new one with 3M 5200. No silicone!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wheeler Dealer Quote  Post ReplyReply Direct Link To This Post Posted: June-22-2009 at 1:24am
Chris, Do you still have this part? If you have not installed it, does the piece that holds the flapper come apart from it's housing? That is what I need.
Maybe I should just just replace the whole thing and be done with it. The new parts from CC are easy to get. It is the how to do it and how hard will it be to change this out. The hose clamps inside are easy to get to. The question is how hard will it be to get the part out???
John
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: June-21-2009 at 11:06pm
I may be the one without an original outlet.
Here is a picture of what was on the boat when I bought it 2 years ago, I assumed it was original. It has integrated mounting for a flapper.
lewy2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lewy2001 Quote  Post ReplyReply Direct Link To This Post Posted: June-21-2009 at 10:27pm
John my 89 SN2001 had a damaged outlet as well. I ended up repairing it. Have attached pic to show you how they look standard.
I did try and source a replacement they were Vetus Transom Exhaust connections for 102mm ID exhaust hose. I never went as far as measuring the id of exhaust hose as repaired outlet worked OK.
89 Ski
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wheeler Dealer Quote  Post ReplyReply Direct Link To This Post Posted: June-21-2009 at 2:49pm
Thanks guys for your input. Chris I will check out the site and look into what you did. Thanks! Steve, Is this a part from correct craft or after market part? Thanks for the help.According to the original owner it has not been changed. Invertaflo into 4" and out. Thanks again guys. I know many say I do not need it but I would like to run with it on just in case.
86BFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 86BFN Quote  Post ReplyReply Direct Link To This Post Posted: June-19-2009 at 11:51pm
You have an 89 with Single? I'd be looking for a polished stainless of chrome w/internal flapper. BTJM
👣 Steve
86 Barefoot Nautique
89 Martinique
Former Owner: 93 Hydrodyne 350 MAG
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: June-19-2009 at 8:35pm
John - You can get a new round outlet from Marineexhaust.com. Then you can use a clamp-on flapper. The outlet costs about $30. I changed mine so I could put the fresh air exhaust on. It was not hard to change.
Use plenty of 5200 so it doesn't leak.
Good luck!
PS - Now that I looked at it twice, your outlet doesn't look like the original anyway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wheeler Dealer Quote  Post ReplyReply Direct Link To This Post Posted: June-19-2009 at 1:00pm
I have just picked up a 1989 S/N and the outside part of my exhust where the flapper attaches is missing. I have read many of the threads on this site but I have not seen one in refference to this one in particular. I have contacted Correct Craft and the part is no longer made.
Therefore my search has begun for missing part # S8305. This is the fiberglass piece that slides into the ring off the back transom that holds the flapper(single exhaust. Any Help???
Is it possible to just add a piece of schedule 80 pvc and attach clamps and flappers to it?
Any help would be greatly appreciated.
John
