Impeller Change |
swc tique
Newbie Joined: June-18-2009 Location: United States Status: Offline Points: 4 |
Posted: July-07-2009 at 7:52pm |
Thanks - That's VERY helpful.
scottb
Senior Member Joined: July-05-2006 Location: Bolingbrook, IL Status: Offline Points: 376 |
I'm sure there is something around here somewhere, or someone will put a tutorial together. In the meantime, here is a pretty good one that someone posted on Planet Nautique
kapla
pete actually I started twice to try to describe the process but I got fuzzy in the middle and never post it.. I was tryin to get a picture of my engine but no luck...
probable I will do a how to tutorial...as the one you did on the lapping the prop!!! |
<a href="">1992 ski nautique
swc,
Take a look in the reference section for your engine manual. It's pretty easy to do but describing it may be confusing. You know the old saying that a picture is worth a thousand words - the manual should have some pictures. If no luck, come back and we'll try to describe it. |
swc tique
I'm trying to change the impeller on my 1998 - New to the maintenance scene. Can't find anything on here (or anywhere else) with info on the process - Does anyone have any guidance on this. I'm not sure even where the impeller is located other than somewhere in-line with the pump. Thanks.
