1973 skier |
73skier
Newbie Joined: April-12-2005 Location: United States Status: Offline Points: 19 |
Posted: April-13-2005 at 11:58am |
Tim D
Yeah, what David said, do a compression check first. I did a 180 real hard one time and pulled the prop out of the water but no damage. I don't jump wakes with my Mustang.
Tim D
David F
You may have floated a valve(s) which can mean one or more valves hit a piston and bent the valve thus causing the valve to not seal. Do a compression check on all cylinders. If low/no compression, pull the head(s) and get a valve job performed. You can also visually check to make sure you did not knock a hole in the top of a piston.
FWIW: "floating a valve" means that the valve spring is not stronge enough to react quickly enough to the high RPM and thus does not close the valve in time and the piston comes up and hits the open valve. |
73skier
prop came out when i went over a big wake at a high speed.I wasn't running it dry out of the water.It was when i was driving it then made engine rev up and after that it wouldn't run. it now farts and pops out of the carb and pipes
79nautique
why are you running the prop out of water? Now you have also damaged the strut bushings and the stuffbox. Both require water to luberacate them during operation. Does it run rough or back fire a lot?
73skier
need to know if any one can tell me if my timming chain may have jumped time running the prop out of the water at a high rpm????
