clear line from fuel pump |
sam57
Senior Member Joined: December-07-2007 Location: North Canton, O Status: Offline Points: 360 |
Posted: August-01-2009 at 4:04am |
If you have fuel in the clear line, you probably have a bad fuel pump.
Naughty93
Newbie Joined: June-29-2009 Location: Northern CA Status: Offline Points: 28 |
Can this line be hooked up anywhere else? Like the Carb? That's where I have mine running to.
eric lavine
it also acts as a vent and if clogged the pump will not work properly, it actually will breath in and out with the diaphram on the pump
kapla
here is a pic o mine...note its hooked to the pump out of a j style tube then its routed with the water hose..and finally goes to the carb....
<a href="">1992 ski nautique
kapla
its not the main fuel line and is conecteed to a little tube on he upper side of the pump right? if so i should connect to the flame arrestor, as it is a fuel return in case the pump breaks and starts overflowing, instead of leaking to the bilge, it will out it in the carb.....
dogspower
Newbie Joined: July-21-2009 Location: kannapolis,nc Status: Offline Points: 24 |
I have a 74 southwind and was looking the engine over a seen the clear line that comes from the fuel pump was not hooked anywhere where do i need to hook it at
dp1
