Carpet of Exhaust? |
JoelH
Guest |
Posted: April-24-2005 at 9:22pm |
I just removed mine after 16 years. I'm leaving the hose just sitting there as it is. The carpet was basically a giant lab experiment of mold and rotting organic material. I'll take the increased noise in trade for a moist, decomposing mess in my bilge!
kenny g
Senior Member Joined: December-13-2003 Location: United States Status: Offline Points: 318 |
you are exactly right nate.
on one of my boats they used scraps of vinyl around the exaust hoses b-4 they sprayed the fiberglass over the foam. |
kenny g
nates78ski
Platinum Member Joined: January-24-2005 Location: United States Status: Offline Points: 1041 |
I have always removed the carpet and installed closed cell foam strips around the mufflers. This keeps the vibration down and does not collect bilge dirt & moisture like carpet does. I assumed Correct Craft used carpet because they had a lot of scrap carpet around and it was cheap & easy to install.
kenny g
correct craft did this to minimize vibration from the engine.or it could rub a hole in the exaust hose where it runs through the floor.
kenny g
Jeff
Guest |
What is the purpose of the carpet around the exhaust hose and mufflers? Heat or sound deadening? Does is make that much of a difference? My boat doesnt have them, but looking in the diaries I see a lot of boats with the carpet. I am wondering if I should do it.
Thanks Jeff |
