automatic bilge pump swith question |
kapla
Posted: September-30-2009 at 3:22pm |
I finally got the rule-mate 500 pump..I will see tomorrow how to hook it up in the boat...
<a href="">1992 ski nautique
Air206
Seb,
Put a meter on the wires to confirm ....... should be pretty straightforward looking at wires and looking at voltage change during operation. You boat is gonna be tight and working great! Steve |
kapla
I can get the rule 500 that Jody menction for $50...
Pete I though I had the wiring somewhere in my computer but can´t find it..hopefully I will find it searching ... |
Seb,
You should have a wiring diagram or at least the 3 wires should be marked. One will be a ground, one will be the "hot" for automatic mode and the last one will be the "hot" for manual mode. |
kapla
I think i saw them here..in that case how sould I connect the system as I will have the 3 cables from the rule automatic and the 2 of the regular pump? I need to replace any circuit in the dash panel?
Fl Inboards
Grand Poobah Joined: January-20-2008 Location: United States Status: Offline Points: 2119 |
If you can sell the two wire pump and pick up a three wire Rule 500 automatic. They have three wires and have a small computer chip in them that allows for a cycle every two min and also has a manual option. Correct Craft is using the same pump only in a two wire function.
http://www.rule-industries.com/images/resized/01_25s-pc99.jpg |
kapla
I have the original automaitc switch that actually since I own the boat it has never worked good..you put the pump in automatic and if you have water it will start pumping it out....and cut, but then when it starts to take water again to the level that the switch should activate again, it doesn´t. These is the pic of the switch I have.
I I bought a couple of month ago an atwood or rule float type switch to replace this one but the thing is that the wiring differs, the old one has a 3 wire hook up and the new one has only 2 wires..How should I connect the new one to make it work as it should? |
