  New Posts New Posts RSS Feed - 289 Interceptor/ 302 ford wanted
ny_nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ny_nautique Quote  Post ReplyReply Direct Link To This Post Topic: 289 Interceptor/ 302 ford wanted
    Posted: July-15-2011 at 11:40am
Guys - the original post is from November 2009.
connorssons View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote connorssons Quote  Post ReplyReply Direct Link To This Post Posted: July-15-2011 at 11:27am
Call c p machine in ft wayne very good and priced right
sam57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sam57 Quote  Post ReplyReply Direct Link To This Post Posted: July-12-2011 at 1:25pm
I have a complete Commander marine conversion and transmission out of a 79 SkiTique that had a cracked block. You supply a 289 302 or 351 long block and bolt the parts on.
Sam
WaterFamily View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WaterFamily Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2011 at 5:19pm
Do you still need the motor? I have one I am willing to part with for a decent price. email me at ctull8@yahoo.com if your interested!
lhalliii View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lhalliii Quote  Post ReplyReply Direct Link To This Post Posted: November-25-2009 at 10:15pm
I have a 74 302 out of Mustang 17 w/ drive & shaft. It is a running motor.
my contacts are.
9194278664
or
lhalliii@nc.rr.com
ThefishingMechine2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ThefishingMechine2 Quote  Post ReplyReply Direct Link To This Post Posted: November-22-2009 at 12:24am
Careful with the bell housing bolt pattern. The new blocks don't necessarily bolt up to the old bell housings. I'm sure one of the guys can fill in the blanks regarding the details but it has something to do with the quantity and location of the bolts. There's a thread on it someplace too.
I'm confused with you not needing a running engine, can rebuild it, but have a problem with machine work. There must be someone in your area that will bore/grind??? South Bend isn't that remote!!!!
BTW, most people who do their own rebuilds will job out the machine work.
Well the main reason we dont have to do machine work is because of how expensive it can get. Plus it is a hassle, we could probably find someone to machine the block and heads on the motor we have. But then we will have to get tons of parts with it most likely.
Fl Inboards View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fl Inboards Quote  Post ReplyReply Direct Link To This Post Posted: November-21-2009 at 9:37pm
Contact Art Cozier at Correct Craft he has leads on a number of those motors, acozier at correctcraft dot com
Tell him Jody sent ya!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-21-2009 at 8:14pm
Originally posted by ThefishingMechine2 ThefishingMechine2 wrote:
Well we would like a 289 interceptor for our 68 freeport, like it came stock. But, we would also go for the 302 ford because we beleive that will bolt right up.
We would prefer that it was in good condition. Running doesn't matter cause we can rebuild the motor as long as we do not have to machine it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ThefishingMechine2 Quote  Post ReplyReply Direct Link To This Post Posted: November-20-2009 at 4:16pm
