  New Posts New Posts RSS Feed - vortec heads on a ´80 engine
kapla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Topic: vortec heads on a ´80 engine
    Posted: February-12-2010 at 4:08pm
AS far as all replies I was given here and in the corvette forum, its doable and all the old parts can be reused. Chris I´ll wait your comments on this friend..If he had to change pushrods and the lenght he put in there.
Whats is a fact it will be a significant performance gain....
<a href="">1992 ski nautique
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: February-11-2010 at 2:10pm
Originally posted by kapla kapla wrote:
good point in the lifter assy..I think they want to keep the original cam - lifter-rocker-arms (hidraulic flat tappets) is it possible to put them in the vortec heads?
YES put you might have to change push rods, I would have to ask my friend who did this on his cruiser last year if it is a direct replacement
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: February-11-2010 at 9:40am
Yes, without a doubt
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: February-10-2010 at 2:21pm
Fl Inboards View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fl Inboards Quote  Post ReplyReply Direct Link To This Post Posted: February-10-2010 at 12:41pm
will those fill that aplication?
as for the vc plastic or steel any price diference? why plastic? is it lighter? or just cheaper..
but on the other hand sound nice upgrade for my 1973 l-82 vette..are they so?
The small block Chevy changed very little in nearly 50 years of production. The exhaust is the same. I have never installed late model Vortec heads on a 80's-early 90's edition Small block. I am assuming they would work just could not utilize the vortec roller lifter assembly. If one wanted to use roller motor technology one would have to go aftermarket.
As far as the rocker covers I just threw up to versions of poison, both are the same price I have a number of pairs.
peter1234 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter1234 Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2010 at 9:52pm
if its that far apart . a cam might be wise
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter1234 Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2010 at 9:51pm
should be the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2010 at 9:40pm
exhaust manifolds bolt pattern is the same? or will need to replace?
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2010 at 9:32pm
these would be for a friend that has a volvo 290a (chevy based of course) engine from the 1980´s
a valve broke while running and ruined one cylinder sleeve and filled the engine with water..so now they are decidingwether to have the heads rebuilt or buy new...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fl Inboards Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2010 at 9:22pm
Motor came in with fresh water 600 hours, Freeze cracked block that still runs great, just has a 3 inch crack above the freeze plugs. Since the heads are comming off I would have them reconditioned before they go back on something else, then again thats me. Usally that runs about $75 per head. $650.00 comes with valve covers and a new never run PCM High rise dual plane intake manifold that came on the replacement motor . If you want me to have the heads reconditioned tack on another $150. You want steel valve covers or plastic?
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2010 at 9:07pm
jody
tell me more on the heads..condition..hours.. year..are they ready to bolt on or they need some work to be done? you have the valve cover also?
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2010 at 8:42pm
40hp for 650. cant go wrong
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fl Inboards Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2010 at 8:40pm
I have a nice set of Vortec heads that I just got in on a crack block job. Also have a Carb aluminum PCM Vortec manifold with bolts all for $650.00
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2010 at 8:40pm
i forgot to mention that, i thought it was the 4 center bolts?
Waterdog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2010 at 8:36pm
The intake bolts are streight down not angled. You can hog out your intake and it will work but I'd get a vortec intake. The heads are worth about 40 HP just bolting them up.
- waterdog -
78 Ski Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2010 at 8:30pm
yes, and a fine upgrade normally, unless you can find some older .202 fuelie heads, double humps on the outside ends, you can hog out the ports to open also,
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2010 at 7:29pm
Is it possible to put vortec heads on a 1980 engine?
other than a new centerbolt valve cover and new intake what other parts are needed? any performance gain that worth the change?
