1989 Ski Nautique Seat Brackets |
gsmith795 ![]() Newbie ![]() ![]() Joined: June-09-2015 Location: E.Wakefield, NH Status: Offline Points: 35 |
![]() ![]() ![]() ![]() ![]() Posted: July-08-2018 at 10:46pm |
Reviving this email chain as my brackets are bending and starting to fail. Anyone have some spares?
SN89Russ ![]() Newbie ![]() Joined: October-18-2017 Location: NC Status: Offline Points: 5 |
I recently bought an 89 SN 2001 which is missing the observer seat hardware. Does anyone know the exact measurements of the a brackets, so I can make the pieces needed to mount the back rest?
Thanks Russ |
Russ
a.jones_asu ![]() Newbie ![]() Joined: September-16-2010 Status: Offline Points: 3 |
Hi if anyone know where i could find some seat brackets i would appreciate any info also. I am new to the site and always wanted a ski nautique so i am buying an 83 model this month. the boat had the back seat and the driver seat but i didn't see the pole in the center either. i would like to have that also if anyone knows where to find one or how hard the install would be, maybe some one know someone that does good upholstery work for these boats. like i said any information is appreciated.
behindpropeller ![]() Platinum Member ![]() Joined: July-31-2006 Status: Offline Points: 1810 |
If anybody else needs the brackets that attach to the seat back because they are bent please email me tim.cochrane@gmail.com or 330-461-2751
Tim |
Matt-
I fixed the address. Do you have specific parts you need or the whole assembly. Mine are all bent. I plan on making new ones on our cnc mill. Tim |
Vancouver Matt ![]() Senior Member ![]() ![]() Joined: March-09-2010 Location: Vancouver, Can Status: Offline Points: 148 |
Any news Tim?
Matthew
Hi Tim,
The e-mail kept bouncing back to me....twice. Maybe you're in-box is to full? Are you making these pieces up or do you have a set? How much do you want for them and are they the same as the observer's seat brackets on the 1989 Ski Nautique 2001? Regards, Matthew |
Matthew
Matt-
Shoot me an email. tim.cochrane@gmail.com I will have them made on Monday of next week. Tim |
Hello Tim (Behind Propeller)!
Any news on the seat brackets for the 1989 Ski Nautique? I just received my upholestry back and I'm excited to do the install. Take Care, Matthew |
Matthew
Hollywood ![]() Moderator Group ![]() ![]() Joined: February-04-2004 Location: Twin Lakes, WI Status: Offline Points: 13523 |
Those definitely look original. Perhaps someone changed some of the fasteners along the way, or the factory was running low on their SS supply. The threaded rods on the corner pieces are indeed long.
89Ski_Nautique ![]() Senior Member ![]() ![]() Joined: May-26-2009 Location: Windermere, FL Status: Offline Points: 160 |
Hollywood,
Check these out are these the factory observer seat brackets for an '89? I am suspicious since the seat bracker mounting hardware was not stainless steel and the machine screws seemed way too long for through bolt mouting to the bracket(s) and the deck. Thanks. |
83ski2001 ![]() Groupie ![]() Joined: March-05-2010 Location: md Status: Offline Points: 93 |
yeah sorry man i thought u needed the floor brackets the allow the whole seat to flip forward. sorry i couldnt help ya
if anyone does need a set of these brackets, i have 2 sets of them left over. if anyone wants them let me know and just donate a few bucks to the site. thanks |
That bottom pic would be a lot better w/o the pylon in it.
I've toyed with the idea of a gullwing conversion like the early 90s but haven't had the time or motivation. The original setup defintely could be improved upon in many ways. |
Bremsen ![]() Senior Member ![]() Joined: June-26-2005 Location: United States Status: Offline Points: 171 |
These are factory 88, should be the same as the 89. Honestly, I'm going to swap them out for a piano hinge, the factory ones are idiotic. They're a pita to use and barely give you enough room to get to anything in the bow. I won't be getting rid of them though, I keep all my factory parts.
Well I won't be able to snap some pics until the weekend. Post what you have and I'll tell you if it's factory. You might be surprised!
Hollywood, Do you have a photo of the 'Correct' observer seat hinges?
I have just removed the observer's seat backrest ('89 Ski) during my wet sanding project and noticed I most likely I have some "Jerry Rigged" observer seat hinges. Does any one have a photo of the "correct" observer seat hinges for a late 80's - 1989 Ski Nautique? Randy |
OK well if they will work let me know. Feel free to call. 4434970063. Thought I would try to help. Tale care
Oh 83 is different?
Yes, I need the one's for the observer's seat. Regards, Matthew |
Matthew
Hi Tim,
That's great. Please keep me informed. What State are U in? Regards, Matthew |
Matthew
Matt-
I will have a set available in a couple weeks. Tim |
An 83 wouldn't have the same hardware as an 89.
Matthew, you need the hinges for the observer seat backrest? |
That is really awesome. Thank you. I will donate some dollars to the site for sure!
Matthew Viney 2776 Granville Street Vancouver, Canada V6H 3J3 |
Matthew
i have a set from my 83. they are the male/female type. send me an address and u can have them, i dont need them. just donate a few dollars to the site.
Hello,
I am looking for new or used steel seat brackets for the retractable set that allows access to the bow. I have a 1989 Ski Nautique 2001 Regards, Matthew |
Matthew
