  New Posts New Posts RSS Feed - Need Pics '88 "2001"
Keeganino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keeganino Quote  Post ReplyReply Direct Link To This Post Topic: Need Pics '88 "2001"
    Posted: April-29-2010 at 7:54pm
How bout this one from skidim.com?
1973 Skier
AMS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AMS Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2010 at 5:29pm
Thanks Everybody, I had to take a break. It was starting to consume too much of my attention (frustrated) and have other jobs to attend to. I have not seen the mount configuration that I recall seening when in lift. The mounts ( pictured here from side view ) would appear to start at top of cradle and extend downward to bottom of cradle. The transmission housing is much smaller in these pics as well. Is this the Velvet drive set up ? Is there a site with pics of different mounts / transmissions available over the years and application. Thanks Again, Steve
Swatkinz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Swatkinz Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2010 at 1:23pm
AMS,
This photo wasn't taken at your request so it may not show you what you need. I can probably get another photo tonight if you still need help.
Steve
Steve
2011 Sport/Air 200
Excalibur 343
2017 Boatmate Tandem Axle Trailer
Former Malibu owner (07, 09)
Bremsen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bremsen Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2010 at 12:49pm
This might help
form&function View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote form&function Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2010 at 12:42pm
Somebody could have tried a 1.23 conversion only to fail then sold it to a unsuspecting buyer but my first guess would be a owner cheaping out installing what he could get his hands on easy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2010 at 11:18am
Steve,
What happened? Don't be someone who leaves us hanging without getting the answer to the problem!!!
AMS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AMS Quote  Post ReplyReply Direct Link To This Post Posted: April-23-2010 at 9:59pm
No problem solved at this point, speaking to each other will solve nothing at this point. I will get to the problem with mounting with the help of everybody here ( appreciate all the imput ! ). I can confront him with this issue when I am better informed then he. I'm pretty stubburn, compulsive and a perfectionist ( wife hates it ! ), but will take this challenge to learn more. I can say already the pics provided is not the set of mounts on this transmission. I did not have to cut vertical inside walls entirely ( only maybe 2 1/2" down and retained the top portion for mount to rest on. Thanks Steve
MI-nick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MI-nick Quote  Post ReplyReply Direct Link To This Post Posted: April-23-2010 at 3:13pm
there are some photos of my '88 in this thread here that may help.
As far as I can tell, I'm not quite sure...
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-23-2010 at 3:04pm
Take a look at Eric's alignment thread and it may have some pictures you may find interesting. Your Tech may want to look at them too. I thought you solved the problem by cutting out the vertical leg of the cradle? BTW, that's the leg you really don't want to cut out. Now the cradle isn't spreading any fore to aft load at that point.
AMS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AMS Quote  Post ReplyReply Direct Link To This Post Posted: April-23-2010 at 2:51pm
I'm trying to compare the style used and will probably need some actually mounted in hull as well to see how adjustable in most installations. Thanks
storm34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote storm34 Quote  Post ReplyReply Direct Link To This Post Posted: April-23-2010 at 2:50pm
Thats the best I've got. Sorry for all the dust. You might want to look the Form&Functions 2001 v-drive thread. I think he had a few shots in there before he tore it apart.
What exactly are you looking for? There are plenty of folks here who can help out.
88Bishop View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 88Bishop Quote  Post ReplyReply Direct Link To This Post Posted: April-23-2010 at 2:44pm
What specific views do you need? My trans is out right now so I could get some shots of it and the mounts. Let me know if this helps. Mine IS an '88 "2001"
Post Options Post Options   Thanks (0) Thanks(0)   Quote 88Bishop Quote  Post ReplyReply Direct Link To This Post Posted: April-23-2010 at 2:43pm
AMS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AMS Quote  Post ReplyReply Direct Link To This Post Posted: April-23-2010 at 2:31pm
Anybody have rear view pics of transmission with close up view of mounting system. I'm needing to do some comparing and went thru several pages of Diaries ( most only showed engine ). Thanks
